R3GDL
R3GDL
    BIVAR
    插件
    LED GRN DIFF 3.3X1.9MM RECT T/H
R3GDL 数据手册
Rectangular Package Discrete LED GREEN, 2 x 3 mm, Low Current R3GDL ♦ ♦ ♦ ♦ ♦ ♦ ♦ Rectangular Package RoHS Compliant Diffused Lens Available in Standard Lead Frame style Ideal for Status Indication and Bar Graph Displays 2 mA Low Operating Current Recommended for Bivar H-480C holder assemblies Bivar Rectangular 2 x 3mm Package Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget is required such as solar or battery-powered portable devices. The rectangular package makes it ideal for creating bar graph displays when arranged in linear LED arrays. Bivar offers diffused LED lens for uniform light output. The Standard Lead frame LED is ideal for vertical spacer assemblies and Right Angle Holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance Viewing Angle R3GDL GaP/GaP GREEN 568nm Green Diffused 100° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Part Number Designation R 3 X X L LED Body, mm Emitted Color Low Current Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 1 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER GREEN, 2 x 3 mm, Low Current Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 10 mW Forward Current ( DC ) 7 mA Peak Forward Current 1 / mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 2 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX R3GDL / 2.1 2.8 / 2 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP / / / / / 0.4 / 100 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 2 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER GREEN, 2 x 3 mm, Low Current Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° Iv 20° 30° 100° 1.0 40° 50° 60° 0.5 70° 80° λ(nm) 0.0 500 550 600 650 Fig. 1 Relative Luminous Intensity vs. Wavelength 1.2 Vf (V) 90° 0.5 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram 3.0 1.1 0.3 Iv 2.0 1.0 1.0 0.9 0.8 T (°C) -40 0 40 80 Fig. 3 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 4 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 3 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER GREEN, 2 x 3 mm, Low Current Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 07/08 Page Page 4 4 of of 4 4
R3GDL 价格&库存
很抱歉,暂时无法提供与“R3GDL”相匹配的价格&库存,您可以联系我们找货
R3GDL
    • 1+2.93512
    • 200+1.17116
    • 500+1.13206
    • 1000+1.11273
