engineered to light up your design
www.vcclite.com
1.800.522.5546
7018X Series Bicolor SMT LEDs
Description and Features
RED
LE D C HIP
1.60
C AT HODE MAR K
0.15
2
0.70
1
Surface Mount Technology
• Tape and reel packaged for high-speed autoinsertion.
• Convection and vapor-phase reflow compatible.
• Compact form enables high density placement.
• Packaged 4000 per reel.
• RoHS Compliant
1.50
0.85
4
Leading Edge LED Optoelectronic Performance
• Consistent high brightness.
3
1.20
GR E E N
LE D C HIP
1.10
0.70
DIF F US E D
E P OXY
0.20 MIN.
P OLAR IT Y MAR K
• Refer to “Solder Pad Geometry 1.pdf”
0.90
0.20
4
3
2
1
Exceptional Reliability
• Stringent process controls assure quality.
• Extensive qualification testing to meet strictest requirements.
• Designed to permit easy post-reflow solder joint inspection.
0.50
All dimensions in mm.
Electro-Optical Characteristics and Ratings
P AR T NUMB E R
Output C olor
Diffusion
P ackage C olor
T est C urrent (mA)
F orward Voltage Typ. (V)
F orward V oltage Max. (V )
Luminous Intensity Min. (mcd)
Luminous Intensity T yp. (mcd)
Luminous Intensity Max. (mcd)
P eak Wavelength (nm)
Viewing Angle (degrees)
P ower Dissipation (mW)
S torage Temperature (°C )
Operating T emperature (°C )
P eak Forward C urrent Max. (1µs @1 0%duty cy cle) (mA)
R everse V oltage (IR =100µA) (V )
Lead S older T ime @260°C
7018X1/5
R ed/G reen
Diffused
C lear
2.8
4.5
6.4
560
120
70
-40 to +100
-30 to +85
60
4
5
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
VCC:
7018X1/5
很抱歉,暂时无法提供与“7018X1/5”相匹配的价格&库存,您可以联系我们找货
