CC
SM1206AC-IL
Industry Standard 1206 Footprint
RoHS Compliant
Water Clear Inner Lens
High Luminous Intensity
Narrow Viewing Angle
Ideal for Status Indication, Display, and Backlighting
Bivar Surface Mount 1206 Inner Lens package LED may be used in nearly any lighting or indication
application. The water clear inner lens provides a narrow viewing angle and high luminous intensity
making it suitable for small scale applications such as display, backlighting, and general indication. Low
power consumption and excellent long life reliability are ideal for battery powered equipment. Wide variety
of wavelength and intensity combinations are available to meet any illumination need. The SM1206-IL
LED is packaged in standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Peak
Wavelength
λp(nm) TYP.
Lens
Appearance
SM1206AC-IL
GaAsP
Amber
610
Water Clear
Luminous
Intensity (mcd) Viewing Angle
TYP.
18
30°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 06/22
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
78 mW
Forward Current (DC)
Peak Forward Current
30 mA
100 mA
1
Reverse Voltage
5V
Operating Temperature Range
-40 - +85°C
Storage Temperature Range
-40 - +85°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & IF = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
SM1206AC-IL
1.8
2.0
2.3
Notes: 1. Tolerance of forward voltage : ±0.1V.
Reverse
Dominant
Luminous
Current
Wavelength (nm)2 Intensity Iv (mcd)3
(μA)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
10
602
9
18
28.5
30
2. Tolerance of dominant wavelength : ±1.0nm.
3. Tolerance of luminous intensity : ±10%
Revision B 06/22
Page 2 of 5
Typical Electrical / Optical Characteristics
Revision B 06/22
Page 3 of 5
Recommended Soldering Conditions
Temp. (°C)
a 25
b 150
c 200
d 220
e 245
f Max. 260
Belt Speed
Time (Sec)
T0~T1
T1~T2
T2~T4
T3~T6
Max. 3°C/sec
90~130 sec
Max. 3°C/sec
Max. 50sec
Max. 10sec
T5~T7
Max. -3°C/sec
70~90 cm/min
Soldering Iron
1. Temperature at tip of iron: 300°C Max. (25W Max.)
2. Soldering time: 5 ± 1sec.
Tape and Reel Dimensions
Note: 3000 pcs/Reel
Revision B 06/22
Page 4 of 5
2.8 [70mm]
2. Standard tolerance unless otherwise noted: X.XXX ± 0.010"
X.X ± 0.1”
Packaging and Labeling Plan
Note: 1 Reel / Bag
Vacuum and Heat Sealed
Clear AntiStatic Poly Bag
X.XXX
Humidity Indicator
Card
Desiccant
X.XXX
Revision B 06/22
Page 5 of 5
很抱歉,暂时无法提供与“SM1206AC-IL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+3.355213000+0.43392
