CMDA20AYCY7D1S
CMDA20AYCY7D1S
    VCC
    发光二极管/LED 0603
CMDA20AYCY7D1S 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMDA20 Series 0603 Package Size Bicolor Surface Mount LED Description and Features Features • Small 1.6 x 0.8 mm Footprint • Diffused optics • Ideal for use with Light Pipes • Compatible with IR solder profiles • Available in 8 mm tape on 7" diameter reels • Packaged 4,000 pieces per reel • RoHS Compliant NOTES: 1. All dimensions are in millimeters (in). 2. 1 micro second @ 10% duty cycle Applications • Keypad backlighting • Symbol backlighting • LCD backlighting • Status indication • Front panel indicator Electro-Optical Characteristics and Ratings Part Number Output Color Diffusion Package Color Test Current (mA) Forward Forward Voltage Voltage Typ. (V) Max. Typ. (V) Luminous Intensity Min. (mcd) Luminous Intensity Typ. (mcd) Peak Wavelength (nm) Viewing Angle (Degrees) 120 CMDA20AYAA7D1S Green/Amber Diffused White 20 2.2/2.2 2.6/2.6 4/2.5 15/8 570/605 CMDA20AYCY7D1S Green/Yellow Diffused White 20 2.2/2.1 2.6/2.6 4/2.5 15/8 570/589 120 CMDA20AYBR7D1S Green/HE Red Diffused White 20 2.2/2.1 2.6/2.6 4/2.5 15/8 570/630 120 Absolute Maximum Ratings to = 25°C Part Number Power Dissipation (mW) Operating Temperature (°C) Storage Temperature (°C) Peak Forward Current Max. (See note 2) (mA) Reverse Voltage (IR = 100 mA) (V) Lead Solder Time at 230°C (Seconds) AYAA 52 -30 to +85 -40 to +85 100 5 10 AYCY 52 -30 to +85 -40 to +85 100 5 10 AYBR 52 -30 to +85 -40 to +85 100 5 10 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMDA20AYCY7D1S 价格&库存
很抱歉,暂时无法提供与“CMDA20AYCY7D1S”相匹配的价格&库存,您可以联系我们找货
