5GD12V-F
5GD12V-F
    BIVAR
    径向
    LED GRN DIFF 5MM ROUND T/H
5GD12V-F 数据手册
5mm 3mm (T1 Package Package Discrete Discrete LED LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Low Ultra 5V 12V Ultra Super Low Current Bright Ultra Bright Current Bright Bright GREEN, 12V B 5GX12V-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant Water Clear (C) and Diffused (D) Lenses Available in Flange (F) and Standard (Blank) Lead Frame styles 12V Operating Voltage Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package 12V LED is ideal for applications equipped with regular 12V power supplies such as servers and computer peripherals, and applications operated by 12V batteries such as automobiles and boats. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. 5GC12V-F 5GD12V-F 5GC12V GaP/GaP GREEN 568nm 5GD12V Lens Appearance Viewing Angle Water Clear 35° Green Diffused 40° Water Clear 35° Green Diffused 45° Part Number Designation 5 X X 12 V - X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, Blank for Standard 12V Operating Voltage ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Low Ultra Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, 12V Outline Dimensions Flanged “5XX12V-F” LED Standard “5XX12V” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Low Ultra Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, 12V Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation / mW Forward Current ( DC ) 10mA Peak Forward Current 1 12 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & Vf = 12V unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 5GC12V-F 5GD12V-F MAX / / 12 / / / 100 / / 12 / / / 100 5GC12V 5GD12V Reverse Dominant Current Wavelength (nm)2 (μA) Notes: 1. Tolerance of forward voltage : ±0.05V. Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 35 / / / / 25 / 40 / / / / 40 / 35 / / / / 25 / 45 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Low Ultra Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, 12V Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Iv 0° 10° 20° 30° 1.0 40° 35° 50° 40° 45° 0.5 60° 70° 0.0 500 80° λ(nm) 550 600 90° 650 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Fig. 1 Relative Luminous Intensity vs. Wavelength Iv 3.0 2.0 1.0 0.0 T (°C) -40 0 40 80 Fig. 3 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER TURQUOISE, BLUE, YELLOW, AMBER, GREEN, Low Ultra Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, 12V Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 5 of of 4 5
5GD12V-F 价格&库存
很抱歉,暂时无法提供与“5GD12V-F”相匹配的价格&库存,您可以联系我们找货
5GD12V-F
