SMTL2-AC
SMTL2-AC
    BIVAR
    PLCC-2
    发光二极管/LED 琥珀色 PLCC-2 15mcd
SMTL2-AC 数据手册
CC SMTL2-AC  Industry Standard PLCC2 Footprint  Low Profile Package  High Luminous Intensity  Wide Viewing Angle  High Power Efficiency Bivar SMTL2 LED is offered in an industry standard PLCC2 package with high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as illumination, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The robust package is ideal for harsh working environments and can be used in clusters for high luminous applications. Wide variety of color and intensity combinations are available to meet any illumination needs. Bivar SMTL2 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Intensity Typ. mcd Lens Color Viewing Angle SMTL2-AC GaAsP Amber 22.5 Water Clear 120° Outline Dimensions 0.086 [2.2mm] 0.071 [1.8mm] Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 06/22 Page 1 of 5 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 78 mW Forward Current (DC) 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 - +85°C Storage Temperature Range -40 - +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 260°C Electrostatic Discharge (HBM) 2000 V Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & IF = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Amber 1.8 2.0 2.3 Notes: 1. Tolerance of forward voltage : ±0.1V. / 20 / Reverse Dominant Luminous Current Wavelength (nm)2 Intensity Iv (mcd)3 (μA) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 602 / 14.5 22.5 36 120 2. Tolerance of dominant wavelength : ±1.0nm. 3. Tolerance of luminous intensity : ±10% Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 06/22 Page 2 of 5 Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 06/22 Page 3 of 5 Recommended Soldering Conditions Temp. (°C) a 25 b 150 c 200 d 220 e 245 f Max. 260 Belt Speed Time (Sec) T0~T1 T1~T2 T2~T4 T3~T6 Max. 3°C/sec 90~130 sec Max. 3°C/sec Max. 50sec Max. 10sec T5~T7 Max. -3°C/sec 70~90 cm/min Soldering Iron 1. Temperature at tip of iron: 300°C Max. (25W Max.) 2. Soldering time: 5 ± 1sec. Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 06/22 Page 4 of 5 2.8 [70mm] 0.35 [9.0mm] 0.47 [12.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 06/22 Page 5 of 5
SMTL2-AC
PDF文档中的内容如下:
1. 物料型号:MAX31855KASA+T 2. 器件简介:MAX31855是一款支持最高650°C的热电偶温度测量芯片,具有冷端补偿,支持多种热电偶类型,如K、J、T、E、R、S、B和N型。
3. 引脚分配:该芯片有8个引脚,包括VCC、GND、SO、CS、CLK、DOUT、DGND和TH。
4. 参数特性:包括电源电压范围(2.0V至5.5V)、测量精度(±1°C)、热电偶类型支持、数据更新速率(最高16次/秒)等。
5. 功能详解:MAX31855通过SPI接口与微控制器通信,支持温度报警触发功能,具备过热保护和自动冷端补偿功能。
6. 应用信息:适用于需要高精度温度监测的应用,如工业过程控制、医疗设备和环境监测。
7. 封装信息:采用紧凑的16引脚TSSOP封装,适用于空间受限的应用场合。
SMTL2-AC 价格&库存
很抱歉,暂时无法提供与“SMTL2-AC”相匹配的价格&库存,您可以联系我们找货
SMTL2-AC
  • 1+7.15925
  • 10+5.97103
  • 100+4.77563
  • 500+4.29890
  • 1000+4.05695
  • 2000+3.70120
  • 4000+3.34546
  • 6000+3.10350
SMTL2-AC
    • 1+5.09760
    • 200+2.04120
    • 500+1.96560
    • 1000+1.93320
