PLCC2 SMD Top View Package LED
SMTL2-YC, YELLOW
SMTL2-YC
Industry Standard PLCC2 Footprint
Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMTL2 LED is offered in an industry standard PLCC2 package with high luminous intensity and wide
viewing angles. The miniature package is ideal for small scale applications such as illumination, general
indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The robust package is ideal for harsh working environments and can be used in
clusters for high luminous applications. Wide variety of color and intensity combinations are available to
meet any illumination needs. Bivar SMTL2 LED is packaged in standard tape and reels for pick and
place assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
Lens Color
Viewing Angle
SMTL2-YC
GaAsP
Yellow
16
Water Clear
120°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision A 02/16
Page 1 of 5
SMTL2-YC, YELLOW
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
78 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-40 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Lead Soldering Temperature ( 1.6 mm from body ) 2
260°C
Electrostatic Discharge (HBM)
2000 V
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
Yellow
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current (µA)
VR=5V
Dominant
Wavelength (nm)2
Luminous
Intensity (mcd)3
Viewing
Angle
2 Ө ½ (deg)
TYP
MAX
TYP
MAX
MIN
TYP
MAX
MIN
TYP
TYP
2.0
2.6
582
585
597
10
16
120
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision A 02/16
Page 2 of 5
SMTL2-YC, YELLOW
Typical Electrical / Optical Characteristics Curves
Revision A 02/16
Page 3 of 5
SMTL2-YC, YELLOW
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 2000 pcs/Reel
Revision A 02/16
Page 4 of 5
SMTL2-YC, YELLOW
0.35 [9.0mm]
0.47 [12.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator Card
Desiccant
X.XXX
Bivar Standard Packaging Label
Revision A 02/16
Page 5 of 5
很抱歉,暂时无法提供与“SMTL2-YC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.771761+1.00118
- 10+6.4823110+0.83507
- 100+5.18410100+0.66783
- 500+4.66657500+0.60116
- 1000+4.403411000+0.56726
- 2000+4.017462000+0.51754
- 4000+3.631504000+0.46782
- 6000+3.368356000+0.43392
- 国内价格 香港价格
- 1+1.703601+0.21880
