5UAC-1.5K
5UAC-1.5K
    BIVAR
    径向
    LEDAMBERCLEAR5MMROUNDT/H
5UAC-1.5K 数据手册
REV. DESCRIPTION A Engineering Release Flat Edge Cathode ID DATE APPROVED 02/10/15 J. C. 0.94 [24.0mm] 0.339 [8.6mm] MIN. 0.04 [1.0mm] MIN. Flange Dia. 0.100 [2.5mm] 0.020 [0.5mm] SQ. Flanged LED : P/N: 5UAC-1.5K-F MIN. 0.039 [1.0mm] Recommended Mounting +.003 -.002 0.94 [24.0mm] 0.346 [8.8mm] MIN. 0.04 [1.0mm] MIN. 0.100 [2.5mm] 0.020 [0.5mm] SQ. Non-Flanged LED: P/N: 5UAC-1.5K MIN. ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE CURRENT OPERATING TEMPERATURE RANGE DESIGNED: STORAGE TEMPERATURE Brian Oliver LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) CHECKED: A. Wright DATE: 02/10/15 DATE: 02/10/15 PART NO: FAX: (949) 951-3974 LED TITLE: 5UAC-1.5K-X CAGE CODE : 32559 REVISION: A SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
5UAC-1.5K 价格&库存
很抱歉,暂时无法提供与“5UAC-1.5K”相匹配的价格&库存,您可以联系我们找货
