3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
ORANGE,
Ultra
Super
Ultra
Ultra
Bright
Bright
ORANGE,
UltraBright
Bright
B
3UOC-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear Lens
Available in Flange (F), Standard (Blank), and Shouldered
(S) Lead Frame styles
Up to 300 mcd Luminous Intensity at 20 mA
Ideal for Back Lighting, Status Indication, and Display
Recommended for Bivar Flexible Light Pipe assemblies
Bivar 3mm T1 Package Ultra Bright LED is ideal for those applications where intensive ambient lighting
exists such as Back Lighting, Signage, and Sunlight Readable applications. Bivar offers water clear
LED lens for maximum light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies,
the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends, and the
Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a “-LL” suffix added to the
part numbers.
Part Number
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
3UOC-F
3UOC
AIGaInP
ORANGE
625nm
3UOC-S
Lens Appearance
Viewing Angle
Water Clear
20°
Water Clear
30°
Water Clear
30°
Part Number Designation
3 U X X -X
LED Body, mm
Ultra Bright
Emitted Color
Lead Frame & Body Style
i.e. -F, -S, Blank for Standard
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 04/09
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
Ultra
Super
Ultra
Bright
ORANGE,
UltraBright
Bright
Outline Dimensions
Flanged “3UXX-F” LED
Standard “3UXX” LED
Shouldered Lead “3UXX-S” LED
Standard Lead Only
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 04/09
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
Ultra
Super
Ultra
Bright
ORANGE,
UltraBright
Bright
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
100 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
3UOC-F
3UOC
1.8
2.4
3UOC-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
100
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
300
30
300
30
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 04/09
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
Ultra
Super
Ultra
Bright
ORANGE,
UltraBright
Bright
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
20°
30°
40°
50°
0.5
60°
70°
80°
λ(nm)
0.0
550 600
650 700 750
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
Iv (%)
1000
50
40
100
30
10
.01
1.2
Vf (V)
1.6
2.0 2.4
1
2.8 3.0
10
100
1000
Fig. 4 Relative Luminous Intensity (%) vs.
Forward Current
Fig. 3 Relative Intensity (10mA) vs.
Forward Voltage
50
If (mA)
1
If(mA)
400
Iv (%)
200
40
100
30
10
T (°C)
60
80
100
Fig. 5 Forward Current vs. Temperature
10
T (°C)
-20
0 20 40
60
80 100
Fig. 6 Relative Intensity (%) vs. Temperature
@ 20 mA
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 04/09
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
Ultra
Super
Ultra
Bright
ORANGE,
UltraBright
Bright
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A B
01/16/08
Revision
04/09
Page
Page 4
5 of
of 4
5
