5mm
3mm
(T1
Package
Package
Discrete
Discrete
LED
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
GREEN,
BLUE,
TURQUOISE,
RED,
Ultra
Ultra
Super
Bright
Bright
Ultra
Bright
Bright
Bright
RED, Ultra
Ultra
Bright
B
5SURC-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
Water Clear Lens
Available in Flange (F) and Standard (Blank) Lead Frame
styles
Up to 500 mcd Luminous Intensity at 20 mA
Ideal for Back Lighting, Status Indication, and Display
Bivar 5mm T1 ¾ Package Ultra Bright LED is ideal for those applications where intensive ambient
lighting exists such as Back Lighting, Signage, and Sunlight Readable applications. Bivar offers water
clear LED lens for maximum light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends.
Part Number
5SURC-F
5SURC
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
AlGaInP
RED
640nm
Lens Appearance
Viewing Angle
Water Clear
35°
Water Clear
35°
Part Number Designation
5 U X X -X
LED Body, mm
Ultra Bright
Emitted Color
Lead Frame & Body Style
i.e. -F, -S, Blank for Standard
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 03/08
Page 1 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
BLUE,
TURQUOISE,
GREEN,
YELLOW,
Ultra
Ultra
Super
Ultra
Bright
Ultra
Bright
Bright
Bright
RED, Ultra
Bright
Outline Dimensions
Flanged “5UXX-F” LED
Standard “5UXX” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 03/08
Page 2 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
BLUE,
TURQUOISE,
GREEN,
YELLOW,
Ultra
Ultra
Super
Ultra
Bright
Ultra
Bright
Bright
Bright
RED, Ultra
Bright
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
70 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
5SURC-F
5SURC
1.8
2.4
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
100
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
500
35
500
35
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 3 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
BLUE,
TURQUOISE,
GREEN,
YELLOW,
Ultra
Ultra
Super
Ultra
Bright
Ultra
Bright
Bright
Bright
RED, Ultra
Bright
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
40°
50°
35°
0.5
60°
70°
80°
λ(nm)
0.0
700
600
650
750
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
If (mA)
0.5
0.1
0.2
90°
0.6
0.4
Fig. 2 Directivity Radiation Diagram
Iv
1000
4.0
100
3.0
10
2.0
1
1.0
0.1
Vf (V)
1.0
0.3
2.0
3.0
4.0
If (mA)
0.0
1
5.0
Fig. 3 Forward Current vs. Forward Voltage
10
100
1000
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Iv
Vf (V)
3.0
1.2
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 4 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
BLUE,
TURQUOISE,
GREEN,
YELLOW,
Ultra
Ultra
Super
Ultra
Bright
Ultra
Bright
Bright
Bright
RED, Ultra
Bright
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
03/08
Page
Page 4
5 of
of 4
5
