5mm
3mm
(T1
Package
Package
Discrete
Discrete
LED
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
5V
12V
Ultra
Super
Low
Current
Bright
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
B
5AC12V-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
Water Clear (C)
Available in Flange (F) and Standard (Blank) Lead Frame
styles
12V Operating Voltage
Ideal for Status Indication and Display
Bivar 5mm T1 ¾ Package 12V LED is ideal for applications equipped with regular 12V power supplies
such as servers and computer peripherals, and applications operated by 12V batteries such as
automobiles and boats. Bivar offers water clear LED lens for maximum light output. The Flanged LED
is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical
spacer assemblies without lead bends.
Part Number
5AC12V-F
5AC12V
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaAsP/GaP
AMBER
605nm
Lens Appearance
Viewing Angle
Water Clear
35°
Water Clear
35°
Part Number Designation
5 X X 12 V - X
LED Body, mm
Emitted Color
Lens Appearance
Lead Frame & Body Style
i.e. -F, Blank for Standard
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 09/12
Page 1 of 5
3mm
Package
Discrete
LED
LEDs
5mm (T1)
(T1 ¾)
Package
Discrete
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
Outline Dimensions
Flanged “5XX12V-F” LED
Standard “5XX12V” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 09/12
Page 2 of 5
3mm
Package
Discrete
LED
LEDs
5mm (T1)
(T1 ¾)
Package
Discrete
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
/ mW
Forward Current ( DC )
10mA
Peak Forward Current 1
12 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & Vf = 12V unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MAX
MIN
TYP
MAX
MIN
TYP
MAX
TYP
5AC12V-F
12
100
40
35
5AC12V
12
100
40
35
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 09/12
Page 3 of 5
3mm
Package
Discrete
LED
LEDs
5mm (T1)
(T1 ¾)
Package
Discrete
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
Typical Electrical / Optical Characteristics
Iv
0°
1.0
10°
20°
30°
40°
35°
50°
40°
45°
0.5
60°
70°
0.0
550
80°
λ(nm)
600
650
700
750
90°
0.5
Fig. 1 Relative Luminous Intensity vs. Wavelength
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Fig. 3 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 09/12
Page 4 of 5
3mm
Package
Discrete
LED
LEDs
5mm (T1)
(T1 ¾)
Package
Discrete
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
09/12
Page
Page 4
5 of
of 4
5
