3AC12V-S
3AC12V-S
    BIVAR
    T-1(3mm)
    发光二极管/LED 径向
3AC12V-S 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN, TURQUOISE, BLUE, AMBER, YELLOW, Low Ultra 5V Ultra Super Low 12V Current Bright Ultra Bright Current Bright Bright AMBER, 12V B 3AX12V-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C) and Diffused (D) Lenses Available in Flange (F) and Shouldered (S) Lead Frame styles 12V Operating Voltage Ideal for Status Indication and Display Bivar 3mm T1 Package 12V LED is ideal for applications equipped with regular 12V power supplies such as servers and computer peripherals, and applications operated by 12V batteries such as automobiles and boats. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. 3AC12V-F 3AD12V-F 3AC12V-S GaAsP/GaP AMBER 605nm 3AD12V-S Lens Appearance Viewing Angle Water Clear 20° Amber Diffused 35° Water Clear 30° Amber Diffused 40° Part Number Designation 3 X X 12 V - X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, -S 12V Operating Voltage ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 1 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER, 12V Outline Dimensions Flanged “3XX12V-F” LED Shouldered Lead “3XX12V-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 2 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER, Super Bright AMBER, 12V Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation / mW Forward Current ( DC ) Peak Forward Current 10mA 1 12 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & Vf = 12V unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3AC12V-F 3AD12V-F MAX / / 12 / / / 100 / / 12 / / / 100 3AC12V-S 3AD12V-S Reverse Dominant Current Wavelength (nm)2 (μA) Notes: 1. Tolerance of forward voltage : ±0.05V. Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / 20 40 / 20 / / / 10 25 / 35 / / / 20 40 / 30 / / / 10 25 / 40 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 3 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER, Super Bright AMBER, 12V Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 20° 30° 35° 50° 40° 0.5 60° 70° 80° 0.0 550 λ(nm) 600 650 700 90° 750 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Fig. 1 Relative Luminous Intensity vs. Wavelength Iv 3.0 2.0 1.0 0.0 T (°C) -40 0 40 80 Fig. 3 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 4 of 5 3mm (T1) Package Package Discrete Discrete LED LEDs 3mm (T1) AMBER AMBER, Super Bright AMBER, 12V Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A B 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
3AC12V-S 价格&库存
很抱歉,暂时无法提供与“3AC12V-S”相匹配的价格&库存,您可以联系我们找货
