3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
GREEN,
TURQUOISE,
BLUE,
AMBER,
YELLOW,
Low
Ultra
5V
Ultra
Super
Low
12V
Current
Bright
Ultra
Bright
Current
Bright
Bright
AMBER,
12V
B
3AX12V-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C) and Diffused (D) Lenses
Available in Flange (F) and Shouldered (S) Lead Frame
styles
12V Operating Voltage
Ideal for Status Indication and Display
Bivar 3mm T1 Package 12V LED is ideal for applications equipped with regular 12V power supplies
such as servers and computer peripherals, and applications operated by 12V batteries such as automobiles and boats. Bivar offers water clear LED lens for maximum light output and diffused LED lens
for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The
Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a
built in strain relief feature which is ideal for right angle holder assemblies that require lead bends.
Part Number
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
3AC12V-F
3AD12V-F
3AC12V-S
GaAsP/GaP
AMBER
605nm
3AD12V-S
Lens Appearance
Viewing Angle
Water Clear
20°
Amber Diffused
35°
Water Clear
30°
Amber Diffused
40°
Part Number Designation
3 X X 12 V - X
LED Body, mm
Emitted Color
Lens Appearance
Lead Frame & Body Style
i.e. -F, -S
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision B 06/15
Page 1 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER, 12V
Outline Dimensions
Flanged “3XX12V-F” LED
Shouldered Lead “3XX12V-S” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 06/15
Page 2 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER,
Super Bright
AMBER, 12V
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
/ mW
Forward Current ( DC )
Peak Forward Current
10mA
1
12 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & Vf = 12V unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
3AC12V-F
3AD12V-F
MAX
12
100
12
100
3AC12V-S
3AD12V-S
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
Notes: 1. Tolerance of forward voltage : ±0.05V.
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
25
35
30
10
25
40
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 06/15
Page 3 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER,
Super Bright
AMBER, 12V
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
40°
20°
30°
35°
50°
40°
0.5
60°
70°
80°
0.0
550
λ(nm)
600
650
700
90°
750
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Fig. 1 Relative Luminous Intensity vs. Wavelength
Iv
3.0
2.0
1.0
0.0
T (°C)
-40
80
Fig. 3 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 06/15
Page 4 of 5
3mm
(T1) Package
Package Discrete
Discrete LED
LEDs
3mm (T1)
AMBER
AMBER,
Super Bright
AMBER, 12V
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Anti-Static Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A B
01/16/08
Revision
06/15
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“3AD12V-F”相匹配的价格&库存,您可以联系我们找货
