4304H5-468
4304H5-468
    VCC
    T-13/4(5mm)
    发光二极管/LED T-13/4(5mm)
4304H5-468 数据手册
4304H Series Solid State LED Lamps T-1 3/4 (5mm) Key Features • Low power consumption • T-1 3/4 diameter package • 4 colors available: red, amber, green and yellow • Long life - solid state reliability • Reliable and rugged Product Dimensions All dimensions in inches. Ø.224/.248 Ø.189/.205 .331/.354 .039 MAX. .039 .020 S Q.T Y P . .945 MIN. .059/.138 MIN. ANODE .098 the first call for illuminated components www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 03/16 Rev 1 Product Specifications P AR T NUMB E R Output C olor Diffusion P ackage C olor T est C urrent (mA) F orward Voltage Typ. (V) Luminous Intensity Min. (mcd) Luminous Intensity T yp. (mcd) Luminous Intensity M a x . (mcd) D o m i n a n t Wavelength (nm) Viewing Angle 20 1/2 (degrees) P ower Dissipation (mW) R everse Voltage (V) 4304H1 R ed Diffused R ed 10 2.0 3.6 10 630 40 60 3 4304H5 G reen Diffused G reen 10 2.1 5.6 16 572 40 75 3 4304H3 Amber Diffused Amber 10 1.9 3.8 9.7 602 60 135 5 4304H7 Y ellow Diffused Y ellow 10 2.1 5.6 16 585 40 60 3 Electrical Characteristics Curves Forward current vs. forward voltage Luminous Intensity vs. Atmosphere Temperature 4304H1,4304H5 4304H7 4304H1 4304H5 4304H7 Derating Luminous Intensity vs. Forward Current AMBIENT TEMPERATURE: Ta [oC] FORWARD CURRENT: IF [mA] 4304H1 4304H5 4304H7 the first call for illuminated components 4304H1,4304H7 4304H5 www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 03/16 Rev 1 Electrical Characteristics Curves Color: Amber (4304H3) Forward current vs. forward voltage characteristics Relative luminous intensity vs. Maximum tolerable peak current vs. pulse duration.(IDC MAX as per MAX ratings) DC forward current Relative efficiency (luminous intensity per unit current) vs. peak LED current Relative luminous intensity vs. angular displacement Compliances and Approvals the first call for illuminated components www.vcclite.com CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 1.800.522.5546 03/16 Rev 1
4304H5-468 价格&库存
很抱歉,暂时无法提供与“4304H5-468”相匹配的价格&库存,您可以联系我们找货
