3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
YELLOW/GREEN,
YELLOW/GREEN, Bi-Color
Bi-Color
3BC-Y/G-X
Industry Standard 3mm (T1) Package
RoHS Compliant
2-Lead Bi-Color LED
White Diffused Lens
Available in Flange (F) and Shouldered (Blank) Lead Frame
styles
Ideal for Status Indication and Display
Bivar 3mm T1 Package 2-Lead Bi-Color LED is ideal for those applications where dual signals need to
be displayed at the same location such as standby-on indication for server or computer peripherals.
Bivar offers white diffused LED lens for uniform light output and the 2-lead package simplifies the circuitry design where a reverse voltage is available. The Flanged LED is ideal for Panel Mount Clip &
Ring assemblies and the Shouldered Lead frame LED has a built in strain relief feature which is ideal
for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a
“-LL” suffix added to the part numbers.
Part Number
3BC-Y/G-F
3BC-Y/G
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaAsP/GaP
YELLOW
590nm
GaP/GaP
GREEN
568nm
GaAsP/GaP
YELLOW
590nm
GaP/GaP
GREEN
568nm
Lens Appearance
Viewing Angle
White Diffused
45°
Part Number Designation
3 B C - X X-X
LED Body, mm
Bi-Color
Lead Frame & Body Style
i.e. -F, Blank for Shouldered
2nd Emitted Color
1st Emitted Color
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 03/09
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 03/09
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part
Number
Emitted
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
3BC-Y/G-F
3BC-Y/G
Yellow
2.0
2.8
Green
2.1
2.8
Yellow
2.0
2.8
Green
2.1
2.8
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Notes: 1. Tolerance of forward voltage : ±0.05V.
MIN
Viewing
Angle
2Ө½
(deg)
Luminous
Intensity Iv
(mcd)
TYP MAX MIN TYP MAX
4
6
4
6
TYP
45
45
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 03/09
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
45°
50°
0.5
60°
70°
80°
0.0
500
λ(nm)
550
600
650
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
2.0
3.0
4.0
5.0
Vf (V)
Fig. 3 Forward Current vs. Forward Voltage
0.0
1
10
100
1000
If (mA)
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
1.2
3.0
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 03/09
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A B
01/16/08
Revision
03/09
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“3BC-Y/G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.194471+0.67235
- 10+4.3301810+0.56048
- 100+3.45716100+0.44748
- 250+3.11669250+0.40341
- 500+2.94208500+0.38081
- 1000+2.680181000+0.34691
- 2000+2.418272000+0.31301
- 4000+2.252404000+0.29154
- 国内价格
- 1+4.82234
- 10+4.01982
- 100+3.21010
- 250+2.89388
- 500+2.73098
- 1000+2.48783
- 2000+2.24468
- 4000+2.09136
