3BCC-Y/G-F
3BCC-Y/G-F
    BIVAR
    径向
    LED GREEN/YLW CLEAR 3MM RND T/H
3BCC-Y/G-F 数据手册
REV. DESCRIPTION A Engineering Release B Added R/Y & A/G LED Specs C Added LED Specs DATE APPROVED 01/15/09 05/06/10 02/10/15 T. Y. T. Y. J. C. 0.177 [4.5mm] 1.00 [25.4mm] MIN. 0.04 [1.0mm] MIN. N-Flange Dia. 0.100 [2.5mm] 0.020 [0.5mm] SQ. MIN. Shouldered Lead "3BCC-XX" LED Recommended Mounting +.003 -.002 0.209 [5.3mm] Flat Edge ID 1.00 [25.4mm] MIN. 0.04 [1.0mm] Flange Dia. MIN. 0.100 [2.5mm] 0.020 [0.5mm] SQ. MIN. Flanged "3BCC-XX-F"LED 0.032 [0.8mm] SHORT LEAD CATHODE PART NO. LONG LEAD CATHODE RED 3BCC-X GREEN YELLOW 3BCC-Y/G-X GREEN RED 3BCC-R/Y-X YELLOW AMBER 3BCC-A/G-X GREEN STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) DECIMALS REVERSE VOLTAGE 5V REVERSE CURRENT 100uA ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 T1 (3mm) BI-COLOR LED OPERATING TEMPERATURE RANGE DESIGNED: STORAGE TEMPERATURE Raffy Paje CHECKED: LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) FAX: (949) 951-3974 TITLE: F. Jensen DATE: 01/15/09 DATE: 01/15/09 PART NO: REVISION: 3BCC-XX-X CAGE CODE : 32559 C SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SEE SHEET #1 STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T1 (3mm) BI-COLOR LED DESIGNED: Raffy Paje CHECKED: F. Jensen DATE: 01/15/09 DATE: 01/15/09 PART NO: REVISION: 3BCC-XX-X CAGE CODE : 32559 C SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
3BCC-Y/G-F 价格&库存
很抱歉,暂时无法提供与“3BCC-Y/G-F”相匹配的价格&库存,您可以联系我们找货
