REV.
DESCRIPTION
A Engineering Release.
DATE
APPROVED
02/03/15
J. C.
0.340 [8.64mm]
0.079 [2.00mm]
2X 0.100 [2.54mm]
(3)
(2)
(1)
LED DIM.
0.047 [1.20mm]
Shouldered LED:
P/N: 5SBC-3
0.340 [8.64mm]
0.058 [1.47mm]
CATHODE ID
(3)
2X 0.100 [2.54mm]
(2)
(1)
PIN CONFIGURATION
LED DIM.
(2) Common Cathode
0.040 [1.02mm]
FLANDGE DIM.
Flanged LED :
P/N: 5SBC-3-F
(1) Anode
(3) Anode
Red
Green
ABSOLUTE MAXIMUM RATINGS (Ta=25C)
REVERSE VOLTAGE
5V
REVERSE CURRENT
100uA
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
-40C - 80C
-40C - 100C
DESIGNED:
Brian Oliver
CHECKED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
ANGULAR
260C FOR 5 SECONDS
A. Wright
DATE:
02/10/15
DATE:
02/10/15
PART NO:
FAX: (949) 951-3974
T-1 3/4 (5mm)
REVISION:
5SBC-3-X
CAGE CODE : 32559
A
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DESCRIPTION
DATE
APPROVED
SEE SHEET #1
LED
PART NO.
Chip
Absoulute Maximum Ratings
Peak
(nm)
pd
(mW)
If(mA)
If(mA)
WATER CLEAR
30
150
568
WATER CLEAR
30
100
30
SUPER RED
660
WATER CLEAR
HI-EFF GREEN
568
WATER CLEAR
30
100
EMITTED COLOR
PEAK WAVE
P (nm)
SUPER RED
660
HI-EFF GREEN
LENS APPEARANCE
Viewing
Electro-Optical Data
Vf(V)
Type
Iv Typ.
Angle
Max.
(mcd)
(deg)
1.7
2.6
400.0
2.2
2.6
220.0
150
1.7
2.6
400.0
150
2.2
2.6
220.0
5SBC-3
5SBC-3-F
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
Brian Oliver
CHECKED:
A. Wright
DATE:
02/10/15
DATE:
02/10/15
PART NO:
FAX: (949) 951-3974
T-1 3/4 (5mm)
REVISION:
5SBC-3-X
CAGE CODE : 32559
A
SHEET # 2 OF 2
很抱歉,暂时无法提供与“5SBC-3”相匹配的价格&库存,您可以联系我们找货
