SM0805UPGC
SM0805UPGC
    BIVAR
    发光二极管/LED 0805
SM0805UPGC 数据手册
SURFACE MOUNT LED PURE GREEN, 0805 PACKAGE SM0805UPGC ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 0805 Package RoHS Compliant Small Package and Footprint Water Clear Lens Wide Viewing Angle Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 0805 package LED may be used in nearly any lighting or indication application. The miniature package is ideal for small scale applications such as general indication and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar offers water clear LED lens for maximum luminous intensity. Wide variety of wavelength and intensity combinations are available to meet any illumination need. The SM0805 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM0805UPGC InGaN GREEN 510 Water Clear 285 130° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Level 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 1 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 0805 PACKAGE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Forward Current ( DC ) 25 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Dominant Current Wavelength (nm)2 (μA) MIN TYP MAX MIN TYP MAX SM0805UPGC / 3.3 4.2 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. / Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 515 / 145 285 / 130 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 2 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 0805 PACKAGE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 3 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 0805 PACKAGE Recommended Soldering Conditions Tape and Reel Dimensions Note: 4000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 4 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 0805 PACKAGE Packaging and Labeling Plan Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/09 Page Page 4 5 of of 4 5
SM0805UPGC 价格&库存
很抱歉,暂时无法提供与“SM0805UPGC”相匹配的价格&库存,您可以联系我们找货
