3BC-R/Y
3BC-R/Y
    BIVAR
    径向
    LED RED/YLW DIFF 3MM ROUND T/H
3BC-R/Y 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED RED/YELLOW, RED/YELLOW, Bi-Color Bi-Color 3BC-R/Y-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant 2-Lead Bi-Color LED White Diffused Lens Available in Flange (F) and Shouldered (Blank) Lead Frame styles Ideal for Status Indication and Display Bivar 3mm T1 Package 2-Lead Bi-Color LED is ideal for those applications where dual signals need to be displayed at the same location such as standby-on indication for server or computer peripherals. Bivar offers white diffused LED lens for uniform light output and the 2-lead package simplifies the circuitry design where a reverse voltage is available. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a “-LL” suffix added to the part numbers. Part Number 3BC-R/Y-F 3BC-R/Y Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAsP/GaP RED 625nm GaAsP/GaP YELLOW 590nm GaAsP/GaP RED 625nm GaAsP/GaP YELLOW 590nm Lens Appearance Viewing Angle White Diffused 45° Part Number Designation 3 B C - X X-X LED Body, mm Bi-Color Lead Frame & Body Style i.e. -F, Blank for Shouldered 2nd Emitted Color 1st Emitted Color ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 1 of 6 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER YELLOW/GREEN, Bi-Color RED/YELLOW, Bi-Color Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 2 of 6 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER YELLOW/GREEN, Bi-Color RED/YELLOW, Bi-Color Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Emitted Color Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3BC-R/Y-F 3BC-R/Y Red / 2.0 2.8 Yellow / 2.0 2.8 Red / 2.0 2.8 Yellow / 2.0 2.8 Reverse Dominant Current Wavelength (nm)2 (μA) MAX / 20 / / / 20 / / Notes: 1. Tolerance of forward voltage : ±0.05V. MIN Viewing Angle 2Ө½ (deg) Luminous Intensity Iv (mcd) TYP MAX MIN TYP MAX / / / / 6 / / / / / 4 / / / / / 6 / / / / / 4 / TYP 45 45 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 3 of 6 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER YELLOW/GREEN, Bi-Color RED/YELLOW, Bi-Color Typical Electrical / Optical Characteristics - Red TA = 25°C unless otherwise noted 0° Iv 20° 10° 30° 1.0 40° 45° 50° 0.5 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA Iv 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv (%) 1000 50 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 2.8 3.0 1 Fig. 3 Relative Intensity (10mA) vs. Forward Voltage 50 If (mA) 1 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current If(mA) 400 Iv (%) 200 40 100 30 20 50 10 20 T (°C) 0 0 20 40 60 80 100 Fig. 5 Forward Current vs. Temperature 10 T (°C) -20 0 20 40 60 80 100 Fig. 6 Relative Intensity (%) vs. Temperature @ 20 mA Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 4 of 6 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER YELLOW/GREEN, Bi-Color RED/YELLOW, Bi-Color Typical Electrical / Optical Characteristics - Yellow TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 45° 50° 0.5 60° 70° 80° 0.0 500 λ(nm) 550 600 650 700 90° 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 03/09 Page 5 of 6 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER YELLOW/GREEN, Bi-Color RED/YELLOW, Bi-Color Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A B 01/16/08 Revision 03/09 Page Page 4 6 of of 4 6
3BC-R/Y 价格&库存
很抱歉,暂时无法提供与“3BC-R/Y”相匹配的价格&库存,您可以联系我们找货
