5XRC8.515
5XRC8.515
    BIVAR
    径向
    发光二极管/LED 径向
5XRC8.515 数据手册
REV. R T U DATE APPROVED 06/12/15 09/01/15 06/15/17 J. C. J. C. J. C. DESCRIPTION Removed P/Ns, Ref. EOL NOTICE 051915 Updated LED Optical Characteristics Updated LED Optical Characteristics 0.346±0.020 [8.8mm±0.5mm] 0.94 [24.0mm] MIN. Ø.197 [Ø5.0mm] 0.04 [1.0mm] MIN. 0.100 [2.5mm] 0.020 [0.5mm] SQ. MIN. 0.339 [8.6mm] Flat Edge Cathode ID Recommended Mounting Hole Size = Ø.032+.003 -.002 0.94 [24.0mm] MIN. Ø.224 [Ø5.7mm] Flange Dia. ( F Series ) 0.04 [1.0mm] Ø.197 [Ø5.0mm] 0.020 [0.5mm] SQ. MIN. 0.100 [2.5mm] MIN. 0.039 [1.0mm] TABLE 1 5CCLN.NVVX LED DIAMETER (mm) Color Blue Green Red Yellow "F" FOR FLANGED, " " FOR N-FLANGED EMITTING COLOR (SEE TABLE 1) INTERNAL CODE LENS APPEARANCE (SEE TABLE 2) INTERNAL CODE ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) REVERSE VOLTAGE 5V 100µA OPERATING TEMPERATURE RANGE -40°C ~ 85°C STORAGE TEMPERATURE -40°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds Color Code BW G XR Y Lens Appearance Lens Code Water Clear Diffused C D STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS REVERSE CURRENT ( VR=5V) TABLE 2 .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 12/23/02 DATE: 12/23/02 T-1¾ (5mm) & FLANGED LED, COLOR REVISION: PART NO: 5CCLN.NVVX CAGE CODE : 32559 U SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Chip LED Part No. 5BWC2.515 5BWC2.515F 5BWD0.345 5BWD0.345F 5GC9.015F 5YC5.523 5YC5.523F 5XRC2.723 5XRC2.723F 5XRC8.515 5XRC8.515F Material InGaN/Sapphire InGaN/Sapphire InGan InGan AlGalnP AlGalnP AlGalnP AlGalnP AlGalnP AlGalnP Absolute Max. Rating Peak Wavelength λp (nm) Emitted Color 468 468 470 470 528 590 590 630 630 635 635 BLUE BLUE BLUE BLUE GREEN YELLOW YELLOW RED RED RED RED Lens Appearance WATER CLEAR WATER CLEAR DIFFUSED DIFFUSED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Pd (mW) 76 76 70 70 120 75 75 75 75 100 100 If (mA) 20 20 20 20 30 30 30 30 30 35 35 Electro-Optical Data @20mA Vf (V) Peak If (mA) 100 100 70 70 150 100 100 100 100 100 100 TYP 3.2 3.2 3.2 3.2 3.6 2.2 2.2 2.2 2.2 2.2 2.2 lv (mcd) MAX 3.6 3.6 3.6 3.6 4.0 2.4 2.4 2.4 2.4 2.7 2.7 MIN 3000 8000 600 800 8000 4000 4000 2000 2000 6000 6000 TYP 5000 10000 1000 1500 9000 5500 5500 2700 2700 8500 8500 MAX 7000 18000 2000 3000 10000 7000 7000 4000 4000 10200 10200 Viewing Angle 2θ 1/2 (Deg) 25 25 45 45 15 23 23 23 23 15 15 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° DESIGNED: D. Green CHECKED: M. Chen ± 5° DATE: 12/23/02 DATE: 12/23/02 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 3/4 (5mm) & FLANGED LED, COLOR REVISION: PART NO: 5CCLN.NVVX CAGE CODE : 32559 U SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
5XRC8.515 价格&库存
很抱歉,暂时无法提供与“5XRC8.515”相匹配的价格&库存,您可以联系我们找货
