3SBC-A/G-F
3SBC-A/G-F
    BIVAR
    径向
    LEDAMBER/GRNDIFF3MMROUNDT/H
3SBC-A/G-F 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED YELLOW/GREEN, Bi-Color AMBER/GREEN, Bi-Color 3SBC-A/G-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant 2-Lead Super Bright Bi-Color LED White Diffused Lens Available in Flange (F) and Shouldered (Blank) Lead Frame styles Ideal for Status Indication and Display Bivar 3mm T1 Package Bi-Color LED is ideal for those applications where dual signals need to be displayed at the same location such as standby-on indication for server or computer peripherals. Bivar offers white diffused LED lens for uniform light output and the 2-lead package simplifies the circuitry design where a reverse voltage is available. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a “LL” suffix added to the part numbers. Part Number 3SBC-A/G-F 3SBC-A/G Material Emitted Color Peak. Wavelength λp(nm) TYP. AlGaInP AMBER 605nm GaP/GaP GREEN 568nm AlGaInP AMBER 605nm GaP/GaP GREEN 568nm Lens Appearance Viewing Angle White Diffused 45° Part Number Designation 3 S B C - X X-X LED Body, mm Super Bright Bi-Color Lead Frame & Body Style i.e. -F, Blank for Shouldered 2nd Emitted Color 1st Emitted Color ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 02/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER/GREEN, Bi-Color Outline Dimensions Flanged “3SBC-XX-F” LED Shouldered Lead “3SBC-XX” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 02/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER/GREEN, Bi-Color Absolute Maximum Ratings TA = 25°C unless otherwise noted Amber - 100 mW Green - 80 mW Power Dissipation Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Operating Temperature Range -40 ~ +80°C Storage Temperature Range -40 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Emitted Number Color Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3SBCA/G-F Amber / 1.8 2.4 Green / 2.1 2.8 3SBCA/G Amber / 1.8 2.4 Reverse Dominant Current Wavelength (nm)2 (μA) MAX TYP MAX MIN TYP MAX / / / / 20 / / / / / 15 / / / / / 20 / / / / / 15 2. Tolerance of dominant wavelength : ±1.0nm. / / 20 / / / 20 / / Green / 2.1 2.8 Notes: 1. Tolerance of forward voltage : ±0.05V. MIN Viewing Angle 2Ө½ (deg) Luminous Intensity Iv (mcd) TYP 45 45 Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 02/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER/GREEN, Bi-Color Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 40° 45° 50° 0.5 60° 70° 80° 0.0 500 550 λ(nm) 600 650 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 02/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER/GREEN, Bi-Color Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 02/15 Page Page 4 5 of of 4 5
3SBC-A/G-F
物料型号:3SBC-A/G-F 和 3SBC-A/G 器件简介:3mm (T1) 封装的双色LED,适用于需要在同一位置显示双信号的应用,如服务器或计算机外设的待机-开指示。
引脚分配:2引脚超亮双色LED,简化了电路设计。
参数特性:正向电流30mA,峰值正向电流150mA,工作温度范围-40至+80°C,存储温度范围-40至+100°C,引脚焊接温度260°C。
功能详解:提供白色散光透镜,确保均匀的光输出,Flanged LED适合面板安装夹环组件,Shouldered Lead frame LED具有内置的抗拉力特性。
应用信息:适用于状态指示和显示。
封装信息:3mm (T1) 封装,符合RoHS标准,有Flange (F) 和 Shouldered (空白) 引脚框架样式。
3SBC-A/G-F 价格&库存
很抱歉,暂时无法提供与“3SBC-A/G-F”相匹配的价格&库存,您可以联系我们找货
