CC
R50RED-5-0080
RoHS Compliant
Low Profile Dome Lens
Automatic Insertion Compatible – Tubular Packaging
Automatic Placement Compatible
High Intensity Output
High Power Efficiency
Bivar R50RED-5-0080 comes with low profile package design incorporating higher forward current to
maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light
distribution. Low power consumption with quick response time means savings in electricity.
Bivar R50RED-5-0080 can be coupled with reflectors or lenses for optimal light distribution needs. Typical
applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting,
and electronic signage.
Part Number
Material
Emitted Color
Intensity Typ. mcd
Lens Color
Viewing Angle
R50RED-5-0080
AlGaInP/GaAs
Red
2000
Water Clear
80°
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision E 05/22
Page 1 of 4
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
75 mW
Forward Current (DC)
20 mA
Peak Forward Current 1
160 mA
Electrostatic Discharge ( Class1 )
1000 V
Reverse Voltage
5V
Operating Temperature Range
-25 - +85°C
Storage Temperature Range
-30 - +80°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 3 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & IF = 20 mA unless otherwise noted
Emitting
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Red
1.8
2.1
2.4
10
Notes: 1. Tolerance of forward voltage : ±0.05V.
15
Reverse
Dominant
Luminous
Current
Wavelength (nm)2 Intensity Iv (mcd)3
(μA)
MAX
MIN
TYP
MAX
MIN
10
617
627
1500 2000
2. Tolerance of dominant wavelength : ±1.0nm.
TYP
Viewing
Angle
2Ө½
(deg)
MAX
TYP
80
3. Tolerance of luminous intensity : ±15%
Directivity Radiation
Relative Luminous Intensity vs. Radiation Angle
Revision E 05/22
Page 2 of 4
Typical Electrical / Optical Characteristics
1.7
1.9
2.1
2.3
2.5
2.7
Revision E 05/22
Page 3 of 4
Recommended Soldering Conditions
TEMP, 260°C ~ 3 SEC
TEMP, 260°C ~ 3 SEC
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 3 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains
a rubber stopper at each end.
Revision E 05/22
Page 4 of 4
很抱歉,暂时无法提供与“R50RED-5-0080”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.635011+2.28260
- 10+14.9286410+1.93230
- 60+8.9921160+1.16390
- 120+8.73020120+1.13000
- 国内价格
- 1+16.39788
- 10+13.88250
- 60+8.36064
- 120+8.12108
