REV.
R
T
U
DATE
APPROVED
06/12/15
09/01/15
06/15/17
J. C.
J. C.
J. C.
DESCRIPTION
Removed P/Ns, Ref. EOL NOTICE 051915
Updated LED Optical Characteristics
0.346±0.020 [8.8mm±0.5mm]
0.94 [24.0mm]
MIN.
Ø.197 [Ø5.0mm]
0.04 [1.0mm]
MIN.
0.100 [2.5mm]
0.020 [0.5mm] SQ.
MIN.
0.339 [8.6mm]
Flat Edge
Cathode ID
Recommended Mounting
Hole Size = Ø.032+.003
-.002
0.94 [24.0mm]
MIN.
Ø.224 [Ø5.7mm]
Flange Dia.
( F Series )
0.04 [1.0mm]
Ø.197 [Ø5.0mm]
0.020 [0.5mm] SQ.
MIN.
0.100 [2.5mm]
MIN.
0.039 [1.0mm]
TABLE 1
5CCLN.NVVX
LED DIAMETER (mm)
Color
Blue
Green
Red
Yellow
"F" FOR FLANGED, " " FOR N-FLANGED
EMITTING COLOR (SEE TABLE 1)
INTERNAL CODE
LENS APPEARANCE (SEE TABLE 2)
INTERNAL CODE
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
REVERSE VOLTAGE
5V
100µA
OPERATING TEMPERATURE RANGE
-40°C ~ 85°C
STORAGE TEMPERATURE
-40°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
Color Code
BW
G
XR
Y
Lens
Appearance Lens Code
Water Clear
Diffused
C
D
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE CURRENT ( VR=5V)
TABLE 2
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
12/23/02
DATE:
12/23/02
T-1¾ (5mm) & FLANGED LED, COLOR
REVISION:
PART NO:
5CCLN.NVVX
CAGE CODE : 32559
U
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
Chip
LED Part No.
5BWC2.515
5BWC2.515F
5BWD0.345
5BWD0.345F
5GC9.015F
5YC5.523
5YC5.523F
5XRC2.723
5XRC2.723F
5XRC8.515
5XRC8.515F
Material
InGaN/Sapphire
InGaN/Sapphire
InGan
InGan
AlGalnP
AlGalnP
AlGalnP
AlGalnP
AlGalnP
AlGalnP
Absolute Max. Rating
Peak
Wavelength
λp (nm)
Emitted
Color
468
468
470
470
528
590
590
630
630
635
635
BLUE
BLUE
BLUE
BLUE
GREEN
YELLOW
YELLOW
RED
RED
RED
RED
Lens
Appearance
WATER CLEAR
WATER CLEAR
DIFFUSED
DIFFUSED
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
Pd
(mW)
76
76
70
70
120
75
75
75
75
100
100
If
(mA)
30
30
30
30
35
35
Electro-Optical Data @20mA
Vf
(V)
Peak
If (mA)
100
100
70
70
150
100
100
100
100
100
100
TYP
3.2
3.2
3.2
3.2
3.6
2.2
2.2
2.2
2.2
2.2
2.2
lv
(mcd)
MAX
3.6
3.6
3.6
3.6
4.0
2.4
2.4
2.4
2.4
2.7
2.7
MIN
3000
8000
600
800
8000
4000
4000
2000
2000
6000
6000
TYP
5000
10000
1000
1500
9000
5500
5500
2700
2700
8500
8500
MAX
7000
18000
2000
3000
10000
7000
7000
4000
4000
10200
10200
Viewing
Angle
2θ 1/2
(Deg)
25
25
45
45
15
23
23
23
23
15
15
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
DESIGNED:
D. Green
CHECKED:
M. Chen
± 5°
DATE:
12/23/02
DATE:
12/23/02
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1 3/4 (5mm) & FLANGED LED, COLOR
REVISION:
PART NO:
5CCLN.NVVX
CAGE CODE : 32559
U
SHEET # 2 OF 2
很抱歉,暂时无法提供与“5BWD0.345F”相匹配的价格&库存,您可以联系我们找货
