5mm
5mm (T1
(T1 ¾)
¾) Package
Package Discrete
Discrete LED
LED
BLUE
BLUE
5BWX-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Flange (F) and Standard (Blank) Lead Frame
styles
Ideal for Status Indication and Display
Bivar 5mm T1 ¾ Package LED may be used in almost any application. Bivar offers water clear LED
lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the
color of the LED. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Standard
Lead frame LED is ideal for vertical spacer assemblies without lead bends.
Part Number
Viewing Angle
5BWC-F
Water Clear
25°
5BWD-F
Blue Diffused
40°
Blue Tinted
25°
Water Clear
20°
5BWD
Blue Diffused
45°
5BWT
Blue Tinted
20°
5BWC
GaN/SiC
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
5BWT-F
Material
BLUE
430nm
Part Number Designation
5 X X - X
LED Body, mm
Emitted Color
Lead Frame & Body Style
i.e. -F, Blank for Standard
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 03/08
Page 1 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
GREEN
YELLOW
RED
BLUE
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 03/08
Page 2 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
GREEN
YELLOW
RED
BLUE
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
150 mW
Forward Current ( DC )
25 mA
Peak Forward Current 1
70 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
30
25
15
40
5BWT-F
30
25
5BWC
30
45
30
5BWC-F
5BWD-F
5BWD
4.0
4.0
4.5
4.5
5BWT
Notes: 1. Tolerance of forward voltage : ±0.05V.
100
100
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 3 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
GREEN
YELLOW
RED
BLUE
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
20°
25°
40°
50°
45°
0.5
60°
70°
80°
0.0
400
90°
λ(nm)
450
500
0.5
550
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
Vf (V)
2.0
3.0
4.0
5.0
Fig. 3 Forward Current vs. Forward Voltage
0.0
If (mA)
1
10
100
1000
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
1.2
3.0
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 4 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
GREEN
YELLOW
RED
BLUE
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
03/08
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“5BWC-F”相匹配的价格&库存,您可以联系我们找货
