5mm
(T1 ¾)
Package
Discrete
LED
3mm (T1)
Package
Discrete
LED
YELLOW
WARM WHITE
3UWCX.XXXW-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear Lens
3100K Color Temperature
Multiple Intensity and Viewing Angle Options
Available in Flange and Standard LED Body styles
Ideal for Status Indication and Display
Bivar’s 3mm T1 Package 3UWC Series LED may be used in almost any application. They are offered
in 3100K color temperature and come in multiple intensity, viewing angle, and body styles. Bivar offers
a water clear LED lens for maximum light output. The Flange LED is ideal for Panel Mount Clip & Ring
assemblies and the Standard LED is ideal for vertical spacer and holder assemblies.
Part Number
Material
Emitted Color
Color Temperature
Lens Appearance
Viewing Angle
3UWC5.035W-F
3UWC8.035W-F
3UWC5.030W
35°
InGaN/Sapphire
WHITE
3100K
35°
Water Clear
30°
3UWC8.030W
30°
Part Number Designation
3UWC X.X XX W - X
BODY STYLE
LED SERIES
COLOR
TEMPERATURE
INTENSITY x 1000
VIEWING
ANGLE
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 12/10
Page 1 of 5
3mm
5mm
(T1 ¾)
Package
Package
Discrete
Discrete
LED
LEDs
LED
3mm (T1)
(T1)
Package
Discrete
LED
AMBER
GREEN
WARM WHITE
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 12/10
Page 2 of 5
3mm
5mm
(T1 ¾)
Package
Package
Discrete
Discrete
LED
LEDs
LED
3mm (T1)
(T1)
Package
Discrete
LED
AMBER
GREEN
WARM WHITE
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
120 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
100mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +80°C
Storage Temperature Range
-30 ~ +80°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
3UWC5.035W-F
3UWC8.035W-F
3UWC5.030W
3UWC8.030W
Reverse
Current
(μA)
MAX
3.0
3.4
3.8
3.0
3.4
3.8
CCT (Kelvin)
MIN
TYP
MAX
3100
3100
Luminous
Intensity Iv (mcd)
MIN
TYP
Viewing
Angle
2Ө½
(deg)
MAX
TYP
4000 5000
35
6000 8000
35
3100
4000 5000
30
3100
6000 8000
30
Notes: 1. Tolerance of forward voltage : ±0.05V.
Directivity Radiation — Relative Luminous Intensity vs. Radiation Angle
Ta = 25°C unless other noted
(30° Viewing Angle)
(35° Viewing Angle)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 12/10
Page 3 of 5
3mm
5mm
(T1 ¾)
Package
Package
Discrete
Discrete
LED
LEDs
LED
3mm (T1)
(T1)
Package
Discrete
LED
AMBER
GREEN
WARM WHITE
Typical Electrical / Optical Characteristics
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 12/10
Page 4 of 5
3mm
5mm
(T1 ¾)
Package
Package
Discrete
Discrete
LED
LEDs
LED
3mm (T1)
(T1)
Package
Discrete
LED
AMBER
GREEN
WARM WHITE
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
12/10
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“3UWC5.030W”相匹配的价格&库存,您可以联系我们找货
