engineered to light up your design
www.vcclite.com
1.800.522.5546
CMDA5 Series HIGH BRIGHTNESS 0805 Package Size Surface Mount LED
Description and Features
Features
• High brightness
• Small size
• Industrial standard 0805
Footprint
• Diffused optics
• Top emitting
• Compatible with IR solder
profiles
• Ideal for use with Light
Pipes
• Available in 8 mm tape on
7" diameter reel
• Packaged 4,000 pieces
per reel
• RoHS Compliant
NOTES:
1. All dimensions are in millimeters (in).
2. 1 micro second @ 10% duty cycle
Applications
• LCD backlighting
• Push button
backlighting
• Front panel indicator
• Symbol indicator
• Microdisplays
• Small message panel
signage
CAUTION: CMDA5AG
is Class 1 ESD
sensitive per MILSTD-1686. Please
observe appropriate
precautions during
handling and
processing.
Electro-Optical Characteristics and Ratings
Part
Number
Output
Color
Diffusion
Package
Color
Test
Current
(mA)
Forward
Voltage
Typ. (V)
CMDA5AG7D1S
Green
Diffused
Clear
3.9
CMDA5AR7D1S
Red
Diffused
Clear
2.4
CMDA5DY7D1S
Amber
Diffused
Clear
2.4
Forward
Luminous
Voltage
Intensity
Max. Typ. (V) Min. (mcd)
Luminous
Intensity
Typ. (mcd)
Peak
Wavelength
(nm)
Viewing
Angle
(Degrees)
40
145
520
140
25
90
637
170
25
90
595
170
Absolute Maximum Ratings to = 25°C
Part
Number
Power
Dissipation
(mW)
Operating
Temperature
(°C)
Storage
Temperature
(°C)
Peak Forward
Current Max.
(See note 2) (mA)
Reverse Voltage
(IR = 100 mA)
(V)
Lead Solder Time
at 230°C
(Seconds)
AG
AR
98
75
-30 to +85
-30 to +85
-40 to +85
-40 to +85
50
100
5
5
10
10
DY
75
-30 to +85
-40 to +85
100
5
10
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“CMDA5AG7D1S”相匹配的价格&库存,您可以联系我们找货
