R20WHT-V-3045
R20WHT-V-3045
    BIVAR
    DIP-4
    LED COOL WHITE CLEAR 4DIP T/H
R20WHT-V-3045 数据手册
4-Pin Super Flux White LED Lamp Orca R Series (Oval Dome) R20WHT-V-3045       RoHS Compliant Low Profile Dome Lens Automatic Insertion Compatible — Tubular Packaging Automatic Placement Compatible High Intensity Output High Power Efficiency Bivar R20WHT-V-3045 comes with low profile package design incorporating higher forward current to maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light distribution. Low power consumption with quick response time means savings in electricity. Bivar R20WHT-V-3045 can be coupled with reflectors or lenses for optimal light distribution needs. Typical applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting, and electronic signage. Part Number Material Emitted Color Intensity Typ. mcd Lens Color Viewing Angle R20WHT-V-3045 InGaN/Sapphire White 16000 Water Clear 30/45° Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 08/15 Page 1 of 4 4-Pin Super Flux White LED Lamp R20WHT-V-3045 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 220 mW Forward Current ( DC ) 50 mA Peak Forward Current 1 100 mA Electrostatic Discharge ( Class1 ) 2000 V Reverse Voltage 5V Operating Temperature Range -25 ~ +80°C Storage Temperature Range -30 ~ +80°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color White Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Viewing Chromaticity Luminous Current (µA) Coordinates (XY)2 / Angle 3 Intensity (mcd) VR=5V 2 Ө ½ (deg) CCT (Kelvin) MIN TYP MAX TYP MAX TYP MIN TYP TYP 2.7 3.2 3.6 20 10 X=0.31 , Y=0.33 6000K 12000 16000 30/45 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Chromaticity Coordinates : ±0.02. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Relative Luminous Intensity vs. Radiation Angle Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 08/15 Page 2 of 4 4-Pin Super Flux White LED Lamp R20WHT-V-3045 Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Fig.5 Relative Luminous Intensity vs. Ambient Temperature Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 08/15 Page 3 of 4 4-Pin Super Flux White LED Lamp R20WHT-V-3045 Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains a rubber stopper at each end. Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision D 08/15 Page 4 of 4
R20WHT-V-3045 价格&库存
很抱歉,暂时无法提供与“R20WHT-V-3045”相匹配的价格&库存,您可以联系我们找货
R20WHT-V-3045
  • 1+20.72354
  • 5+20.41112
  • 25+19.49471
  • 100+19.06774
  • 250+18.64077
库存:23
