3UWC5.035N-F
3UWC5.035N-F
    BIVAR
    3mm
    3UWC5.035N-F
3UWC5.035N-F 数据手册
5mm (T1 ¾) Package Discrete LED 3mm (T1) Package Discrete LED YELLOW NEUTRAL WHITE 3UWCX.XXXN-X        Industry Standard 3mm (T1) Package RoHS Compliant Water Clear Lens 5000K Color Temperature Multiple Intensity and Viewing Angle Options Available in Flange and Standard LED Body styles Ideal for Status Indication and Display Bivar’s 3mm T1 Package 3UWC Series LED may be used in almost any application. They are offered in 5000K color temperature and come in multiple intensity, viewing angle, and body styles. Bivar offers a water clear LED lens for maximum light output. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Standard LED is ideal for vertical spacer and holder assemblies. Part Number Material Emitted Color Color Temperature Lens Appearance Viewing Angle 3UWC5.035N-F 3UWC8.035N-F 3UWC5.030N 35° InGaN/Sapphire WHITE 5000K 35° Water Clear 30° 3UWC8.030N 30° Part Number Designation 3UWC X.X XX N - X BODY STYLE LED SERIES COLOR TEMPERATURE INTENSITY x 1000 VIEWING ANGLE ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 12/10 Page 1 of 5 3mm 5mm (T1 ¾) Package Package Discrete Discrete LED LEDs LED 3mm (T1) (T1) Package Discrete LED AMBER GREEN NEUTRAL WHITE Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 12/10 Page 2 of 5 3mm 5mm (T1 ¾) Package Package Discrete Discrete LED LEDs LED 3mm (T1) (T1) Package Discrete LED AMBER GREEN NEUTRAL WHITE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 120 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 100 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +80°C Storage Temperature Range -30 ~ +80°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3UWC5.035N-F 3UWC8.035N-F 3UWC5.030N 3UWC8.030N Reverse Current (μA) MAX 3.0 3.4 3.8 / 20 / 10 3.0 3.4 3.8 / 20 / 10 CCT (Kelvin) MIN TYP MAX / 5000 / / 5000 / / Luminous Intensity Iv (mcd) MIN TYP Viewing Angle 2Ө½ (deg) MAX TYP 4000 5000 / 35 / 6000 8000 / 35 5000 / 4000 5000 / 30 5000 / 6000 8000 / 30 Notes: 1. Tolerance of forward voltage : ±0.05V. Directivity Radiation — Relative Luminous Intensity vs. Radiation Angle Ta = 25°C unless other noted (30° Viewing Angle) (35° Viewing Angle) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 12/10 Page 3 of 5 3mm 5mm (T1 ¾) Package Package Discrete Discrete LED LEDs LED 3mm (T1) (T1) Package Discrete LED AMBER GREEN NEUTRAL WHITE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 12/10 Page 4 of 5 3mm 5mm (T1 ¾) Package Package Discrete Discrete LED LEDs LED 3mm (T1) (T1) Package Discrete LED AMBER GREEN NEUTRAL WHITE Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 12/10 Page Page 4 5 of of 4 5
3UWC5.035N-F 价格&库存
很抱歉,暂时无法提供与“3UWC5.035N-F”相匹配的价格&库存,您可以联系我们找货
