engineered to light up your design
www.vcclite.com
1.800.522.5546
7011X Series Bicolor SMT LEDs
Description and Features
3.00
C AT HODE MAR K
LE D C HIP #1
1
2
2.50
1.50
Surface Mount Technology
• Tape and reel packaged for high-speed autoinsertion.
• Convection and vapor-phase reflow compatible.
• Compact form enables high density placement.
• Packaged 2500 per reel.
• RoHS Compliant
0.80
Leading Edge LED Optoelectronic Performance
• Consistent high brightness.
LE NS
4
3
2.00
LE D
C HIP #2
1.80
Exceptional Reliability
• Stringent process controls assure quality.
• Extensive qualification testing to meet strictest requirements.
• Designed to permit easy post-reflow solder joint inspection.
0.90
• Refer to “Solder Pad Geometry 1.pdf”
1.00
0.60
0.60 MIN.
4
3
1
2
C ONT AC T S , G OLD P LAT E D (4)
All dimens ions
in mm.
Electro-Optical Characteristics and Ratings
P AR T NUMB E R
Output C olor
Diffused/Non-Diffused
P ackage C olor
P ower Dissipation (mW)
P eak F orward C urrent Max. (mA)
R everse V oltage (IR =100µA) (V )
Operating temperature (°C )
S torage T emperature (°C )
F orward Voltage Typ. (IF =20mA)
F orward Voltage Max. (IF =20mA)
C ontinuous F orward C urrent Max. (mA)
Luminous Intensity Min. (IF=20mA)
Luminous Intensity Max. (IF=20mA)
P eak Wavelength (IF =20mA)
V iewing Angle (degrees)
R ated C urrent (mA)
R everse C urrent Max. (VR =4V )
7011X1/5
R ed/G reen
Non-Diffused
C lear
60/75
70
4
-30 to +85
-30 to +90
1.7/2.1
2.0/2.5
30
6.0/3.0
17.0/7.5
660/560
100
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“7011X5/7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+19.42920
- 200+7.75440
- 500+7.49520
- 1000+7.36560
