engineered to light up your design
www.vcclite.com
1.800.522.5546
CMDA5 Series 0805 Package Size Surface Mount LED
Description and Features
Features
• Small size
• Industry standard 0805
Footprint
• Compatible with IR solder
profiles
• Diffused optics
• Top emitting
• Ideal for use with Light
Pipes
• Available in 8 mm tape on
7” (178 mm) diameter
reels
• Packaged 4,000 pieces
per reel
NOTES:
1. All dimensions are in millimeters (in).
2. 1 micro second @ 10% duty cycle
Applications
• Keypad backlighting
• Push-button
backlighting
• LCD backlighting
• Symbol backlighting
• Front panel indicator
Electro-Optical Characteristics and Ratings
Part
Number
Output
Color
Diffusion
Package
Color
Test
Current
(mA)
Forward
Voltage
Typ. (V)
Forward
Luminous
Voltage
Intensity
Max. Typ. (V) Min. (mcd)
Luminous
Intensity
Typ. (mcd)
Peak
Wavelength
(nm)
Viewing
Angle
(Degrees)
CMDA5AY7D1S
Green
Diffused
Clear
2.6
4.0
15
570
CMDA5CY7D1S
Yellow
Diffused
Clear
2.6
2.5
8
589
170
CMDA5AA7D1S
Orange
Diffused
Clear
2.6
2.5
8
605
170
CMDA5BR7D1S
HE Red
Diffused
Clear
2.6
2.5
10
630
170
CMDA5DR7D1S
Red
Diffused
Clear
2.6
6.3
17
660
170
170
Absolute Maximum Ratings to = 25°C
Part
Number
Power
Dissipation
(mW)
Operating
Temperature
(°C)
Storage
Temperature
(°C)
Peak Forward
Current Max.
(See note 2) (mA)
Reverse Voltage
(IR = 100 mA)
(V)
Lead Solder Time
at 230°C
(Seconds)
10
AY
52
-30 to +85
-40 to +85
100
5
CY
52
-30 to +85
-40 to +85
100
5
10
AA
52
-30 to +85
-40 to +85
100
5
10
BR
52
-30 to +85
-40 to +85
100
5
10
DR
65
-30 to +85
-40 to +85
100
5
10
The model numbers listed above are standard off the shelf parts. For the user who may have a requirement calling for
various color/electrical specifications, a part number can be determined by calling the factory.
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“CMDA5AY7D1Z”相匹配的价格&库存,您可以联系我们找货
