CMDA5AA7D1S
CMDA5AA7D1S
    VCC
    发光二极管/LED 0805
CMDA5AA7D1S 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMDA5 Series 0805 Package Size Surface Mount LED Description and Features Features • Small size • Industry standard 0805 Footprint • Compatible with IR solder profiles • Diffused optics • Top emitting • Ideal for use with Light Pipes • Available in 8 mm tape on 7” (178 mm) diameter reels • Packaged 4,000 pieces per reel NOTES: 1. All dimensions are in millimeters (in). 2. 1 micro second @ 10% duty cycle Applications • Keypad backlighting • Push-button backlighting • LCD backlighting • Symbol backlighting • Front panel indicator Electro-Optical Characteristics and Ratings Part Number Output Color Diffusion Package Color Test Current (mA) Forward Voltage Typ. (V) Forward Luminous Voltage Intensity Max. Typ. (V) Min. (mcd) Luminous Intensity Typ. (mcd) Peak Wavelength (nm) Viewing Angle (Degrees) CMDA5AY7D1S Green Diffused Clear 20 2.2 2.6 4.0 15 570 CMDA5CY7D1S Yellow Diffused Clear 20 2.1 2.6 2.5 8 589 170 CMDA5AA7D1S Orange Diffused Clear 20 2.2 2.6 2.5 8 605 170 CMDA5BR7D1S HE Red Diffused Clear 20 2.1 2.6 2.5 10 630 170 CMDA5DR7D1S Red Diffused Clear 20 1.8 2.6 6.3 17 660 170 170 Absolute Maximum Ratings to = 25°C Part Number Power Dissipation (mW) Operating Temperature (°C) Storage Temperature (°C) Peak Forward Current Max. (See note 2) (mA) Reverse Voltage (IR = 100 mA) (V) Lead Solder Time at 230°C (Seconds) 10 AY 52 -30 to +85 -40 to +85 100 5 CY 52 -30 to +85 -40 to +85 100 5 10 AA 52 -30 to +85 -40 to +85 100 5 10 BR 52 -30 to +85 -40 to +85 100 5 10 DR 65 -30 to +85 -40 to +85 100 5 10 The model numbers listed above are standard off the shelf parts. For the user who may have a requirement calling for various color/electrical specifications, a part number can be determined by calling the factory. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMDA5AA7D1S 价格&库存
很抱歉,暂时无法提供与“CMDA5AA7D1S”相匹配的价格&库存,您可以联系我们找货
