CMDA5BA7D1S
CMDA5BA7D1S
    VCC
    发光二极管/LED 0805
CMDA5BA7D1S 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMDA5 Series HIGH BRIGHTNESS 0805 Package Size Surface Mount LED Description and Features Features • High brightness • Small size • Industrial standard 0805 Footprint • Diffused optics • Top emitting • Compatible with IR solder profiles • Ideal for use with Light Pipes • Available in 8 mm tape on 7" diameter reel • Packaged 4,000 pieces per reel • RoHS Compliant NOTES: 1. All dimensions are in millimeters (in). 2. 1 micro second @ 10% duty cycle Applications • LCD backlighting • Push button backlighting • Front panel indicator • Symbol indicator • Microdisplays • Small message panel signage CAUTION: CMDA5AG is Class 1 ESD sensitive per MILSTD-1686. Please observe appropriate precautions during handling and processing. Electro-Optical Characteristics and Ratings Part Number Output Color Diffusion Package Color Test Current (mA) Forward Voltage Typ. (V) CMDA5AG7D1S Green Diffused Clear 20 3.4 3.9 CMDA5AR7D1S Red Diffused Clear 20 1.9 2.4 CMDA5DY7D1S Amber Diffused Clear 20 1.9 2.4 Forward Luminous Voltage Intensity Max. Typ. (V) Min. (mcd) Luminous Intensity Typ. (mcd) Peak Wavelength (nm) Viewing Angle (Degrees) 40 145 520 140 25 90 637 170 25 90 595 170 Absolute Maximum Ratings to = 25°C Part Number Power Dissipation (mW) Operating Temperature (°C) Storage Temperature (°C) Peak Forward Current Max. (See note 2) (mA) Reverse Voltage (IR = 100 mA) (V) Lead Solder Time at 230°C (Seconds) AG AR 98 75 -30 to +85 -30 to +85 -40 to +85 -40 to +85 50 100 5 5 10 10 DY 75 -30 to +85 -40 to +85 100 5 10 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMDA5BA7D1S 价格&库存
很抱歉,暂时无法提供与“CMDA5BA7D1S”相匹配的价格&库存,您可以联系我们找货
