C5SMT-BJS-CP0S0451
C5SMT-BJS-CP0S0451
    WOLFSPEED
    插件
    LED BLUE CLEAR 5MM OVAL T/H
C5SMT-BJS-CP0S0451 数据手册
CLD-CT965.001 PRODUCT FAMILY DATA SHEET Cree® Screen Master® 5-mm Oval LED C5SMT-BJS PRODUCT DESCRIPTION FEATURES APPLICATIONS The oval LED is specifically designed • Size (mm): 5 • • Color and Typical Dominant Wavelength:Blue (470nm) for variable-message signs and passenger-information signs.The oval- shaped radiation pattern and high luminous intensity ensure that these wide viewing angle and readability in sunlight are essential. (ESS) • Full Color video screen Luminous Intensity (mcd) C5SMT-BJS: (280 - 1100) • Motorway Signs • Variable Message Sign (VMS) • Lead - Free • Advertising signs • RoHS Compliant • Petrol Signs • devices are excellent for wide-fieldof -view outdoor applications where a Electronic Signs & Signals These lamps are made with an advanced optical-grade epoxy that offers superior high-temperature and highmoisture-resistance performance in outdoor signal and sign applications. The encapsulation resin contains antiUV material in order to reduce the effects of long-term exposure to direct WWW.CREE.COM/HB sunlight. Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. the Cree logo are registered trademarks of Cree, Inc. Cree, the Cree logo and XLamp are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 www.cree.com/xlamp Cree 5-mm Oval LED C5SMT-BJS ABSOLUTE MAXIMUM RATINGS (TA = 25°C) Items Symbol Absolute Maximum Rating Unit IF 25 mA IFP 100 mA Reverse Voltage VR 5 V Power Dissipation PD 100 mW Operation Temperature Topr -40 ~ +95 °C Storage Temperature Tstg -40 ~ +100 °C Lead Soldering Temperature Tsol Forward Current Peak Forward Current Note Max. 260°C for 3 sec. max. (3 mm from the base of the epoxy bulb) Note: Pulse width ≤0.1 msec, duty ≤1/10. TYPICAL ELECTRICAL & OPTICAL CHARACTERISTICS (TA = 25°C) Characteristics Symbol Condition Unit Forward Voltage VF IF = 20 mA V Minimum Typical Maximum 3.4 4.0 Forward Voltage VF IF = 1.0 μA V Reverse Current IR VR = 5 V μA Dominant Wavelength λD IF = 20 mA nm 465 470 Luminous Intensity IV IF = 20 mA mcd 280 500 1.7 2.5 100 475 Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 2 Cree 5-mm Oval LED C5SMT-BJS INTENSITY BIN LIMIT (IF = 20 mA) Blue Bin Code Min.(mcd) Max.(mcd) P0 280 390 Q0 390 550 R0 550 770 S0 770 1100 • Tolerance of measurement of luminous intensity is ±15% COLOR BIN LIMIT (IF = 20 mA) Blue Bin Code Min.(nm) Max.(nm) B4 465 470 B5 470 475 • Tolerance of measurement of dominant wavelength is ±1 nm Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 3 Cree 5-mm Oval LED C5SMT-BJS ORDER CODE TABLE* Luminous Intensity (mcd) Color Kit Number Blue Blue Dominant Wavelength Package Min. Max. Color Bin Min. (nm) Color Bin Max. (nm) C5SMT-BJS-CP0S0451 280 1100 B4 465 B5 475 Bulk C5SMT-BJS-CP0S0452 280 1100 B4 465 B5 475 Ammo Notes: 1. The above kit numbers represent order codes that include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each bulk. Single intensity-bin code and single color-bin codes will not be orderable. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 4 Cree 5-mm Oval LED C5SMT-BJS GRAPHS                                                                                                            The above data are collected from statistical figures that do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 5 Cree 5-mm Oval LED C5SMT-BJS MECHANICAL DIMENSIONS All dimensions are in mm. Tolerance is ±0.25 mm unless otherwise noted. An epoxy meniscus may extend about 1.5 mm down the leads. Burr around bottom of epoxy may be 0.5 mm max.   NOTES RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/ EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 6 Cree 5-mm Oval LED C5SMT-BJS KIT NUMBER SYSTEM All dimensions in mm.Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner: Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 7 Cree 5-mm Oval LED C5SMT-BJS PACKAGING Features: • • • • • The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shock during transportation. The boxes are not water resistant, and they must be kept away from water and moisture. The Bulk Pack types of packaging. Max 500 pcs per bulk and Max 2500 pcs per ammo. Bulk Pack Packaging Type: Ammo Pack Packaging Type: xxx xxx R COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT JOWAXXXXX -XX-XXX QTY RANK PCS Iv X ( ) Vf XX ( ) Hue XX ( ) AXXXXXXXXXXX ANODE Label (anti-electrostatic bag) xxx xxx COLOR LED LAMP TYPE LXXXXXXXX-XXX LOT JOWAXXXXX -XX-XXX QTY RANK PCS Iv Vf Hue 20 bags/carton X ( ) XX ( ) XX ( ) AXXXXXXXXXXX Copyright © 2010 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo and XLamp are registered trademarks Copyright © 2011 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc. of Cree, Inc. 8
C5SMT-BJS-CP0S0451 价格&库存
很抱歉,暂时无法提供与“C5SMT-BJS-CP0S0451”相匹配的价格&库存,您可以联系我们找货
