PLCC4 SMD Top View Package LED
SMP4-RGY, RED/GREEN/YELLOW
SMP4-RGY
Industry Standard PLCC4 Footprint
3 Chips in One Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMP4 Tri-Color LED combines three chips in a single package and is offered in an industry standard
PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide viewing angle
making them ideal for small scale applications such as illumination, general indication, and backlighting. The
flexible three chip design allows for a wide variety of lighting options where the chips can be individually
driven or mixed to create different color combinations. The robust package is ideal for harsh working environments and can be clustered in LED arrays for high luminous applications. Low power consumption and
excellent long life reliability are suitable for battery powered equipment. Bivar SMP4 LED is packaged in
standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
AlGaAs
Red
36
GaP
Green
40
GaAsP
Yellow
16
SMP4-RGY
Lens Color
Viewing Angle
Water Clear
120°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
CAUTION: LOOKING DIRECTLY AT
LED WITHOUT SHIELDED EYES
MAY CAUSE DAMAGE TO RETINA.
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision C 10/13
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
72 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Electrostatic Discharge Classification (HBM)
2000 V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-40 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Soldering Temperature2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current (µA)
VR=5V
Dominant
Wavelength (nm)2
Luminous
Intensity (mcd)3
TYP
MAX
TYP
MAX
TYP
MIN
TYP
Red
1.85
2.3
640
18
36
Green
1.9
2.4
570
Yellow
1.9
2.4
585
10
16
Viewing
Angle
2 Ө ½ (deg)
TYP
120
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision C 10/13
Page 2 of 5
Typical Electrical / Optical Characteristics Curves
Yellow
Green
Yellow
Red
Red
Green
Red, Green, Yellow
Red, Green, Yellow
Revision C 10/13
Page 3 of 5
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 2000 pcs/Reel
Revision C 10/13
Page 4 of 5
0.63 [16.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator
Card
X.XXX
Desiccant
Bivar Standard Packaging Label
Revision C 10/13
Page 5 of 5
很抱歉,暂时无法提供与“SMP4-RGY”相匹配的价格&库存,您可以联系我们找货
