SMP4-SRGY
SMP4-SRGY
    BIVAR
    PLCC-4
    发光二极管/LED PLCC-4
SMP4-SRGY 数据手册
PLCC4 SMD Top View Package LED SMP4-SRGY, RED/GREEN/YELLOW SMP4-SRGY ♦ ♦ ♦ ♦ ♦ Industry Standard PLCC4 Footprint 3 Super Bright Chips in One Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP4 Super Bright Tri-Color LED combines three chips in a single package and is offered in an industry standard PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide viewing angle making them ideal for outdoor illumination applications where higher ambient lighting conditions exist. The flexible three chip design allows for a wide variety of lighting options where the chips can be individually driven or mixed to create different color combinations. The robust package is ideal for harsh working environments and can be clustered in LED arrays for high luminous applications. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar SMP4 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd AlGaInP Red 180 InGaN Green 1050 AlGaInP Yellow 180 SMP4-SRGY Lens Color Viewing Angle Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 1 of 5 PLCC4 SMD Top View Package LED SMP4-SRGY, RED/GREEN/YELLOW Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation Red, Yellow - 78 mW Green - 78 mW Continuous Forward Current Red, Yellow - 30 mA Green - 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Electrostatic Discharge Classification (HBM) 2000 V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 TYP MAX TYP MAX TYP MIN TYP Red 1.9 2.6 20 10 625 115 180 Green 3.3 4.5 20 10 525 1050 1450 Yellow 1.9 2.4 20 10 591 115 180 Viewing Angle 2 Ө ½ (deg) TYP 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 2 of 5 PLCC4 SMD Top View Package LED SMP4-SRGY, RED/GREEN/YELLOW Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Yellow Green Red Red, Green, Yellow Green Red, Yellow Red Yellow Green Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 3 of 5 PLCC4 SMD Top View Package LED SMP4-SRGY, RED/GREEN/YELLOW Recommended Soldering Conditions Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 4 of 5 PLCC4 SMD Top View Package LED SMP4-SRGY, RED/GREEN/YELLOW 0.63 [16.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card Desiccant X.XXX Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 5 of 5
SMP4-SRGY
物料型号:SMP4-SRGY
器件简介:该三色LED将三个芯片封装在一个低轮廓的PLCC4标准封装中,具有高亮度和宽视角,适合户外照明应用。
引脚分配:共有四个引脚,其中两个公共阳极,一个绿色阴极,一个红色和黄色阴极。
参数特性: - 发光颜色:红、绿、黄 - 典型亮度:红180mcd,绿1050mcd,黄180mcd - 视场角度:120° - 工作电压:红/黄1.9-2.6V,绿3.3-4.5V - 正向电流:红/黄20mA,绿20mA - 反向电流:最大10mA - 工作温度范围:-40°C至+85°C - 存储温度范围:-40°C至+100°C - 焊接温度:260°C
功能详解:三色LED可以单独驱动或混合以创建不同的颜色组合,适用于恶劣工作环境,并且可以用于高亮度应用的LED阵列。
应用信息:适用于电池供电设备,因为其低功耗和长寿命可靠性。
封装信息:标准胶带和卷轴包装,适用于拾取和放置组装。
SMP4-SRGY 价格&库存
很抱歉,暂时无法提供与“SMP4-SRGY”相匹配的价格&库存,您可以联系我们找货
