SMP4-SRYB
SMP4-SRYB
    BIVAR
    PLCC-4
    发光二极管/LED PLCC-4
SMP4-SRYB 数据手册
PLCC4 SMD Top View Package LED SMP4-SRYB, RED/YELLOW/BLUE SMP4-SRYB      Industry Standard PLCC4 Footprint 3 Super Bright Chips in One Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP4 Super Bright Tri-Color LED combines three chips in a single package and is offered in an industry standard PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide viewing angle making them ideal for outdoor illumination applications where higher ambient lighting conditions exist. The flexible three chip design allows for a wide variety of lighting options where the chips can be individually driven or mixed to create different color combinations. The robust package is ideal for harsh working environments and can be clustered in LED arrays for high luminous applications. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar SMP4 LED is packaged in standard tape and reels for pick and place assemblies. Part Number SMP4-SRYB Material Emitted Color Lumen Typ. mcd AlGaInP Red 180 AlGaInP Yellow 180 InGaN Blue 285 Lens Color Viewing Angle Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 CAUTION: LOOKING DIRECTLY AT LED WITHOUT SHIELDED EYES MAY CAUSE DAMAGE TO RETINA. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision C 10/13 Page 1 of 5 PLCC4 SMD Top View Package LED SMP4-SRYB, RED/YELLOW/BLUE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation Red, Yellow - 78 mW Blue - 100 mW Continuous Forward Current Red, Yellow - 30 mA Blue - 25mA Peak Forward Current 1 100 mA Reverse Voltage 5V Electrostatic Discharge Classification (HBM) 2000 V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 TYP MAX TYP MAX TYP MIN TYP Red 1.9 2.4 20 10 631 115 180 Yellow 1.9 2.4 20 10 591 115 180 Blue 3.2 3.5 20 10 470 115 285 Viewing Angle 2 Ө ½ (deg) TYP 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision C 10/13 Page 2 of 5 PLCC4 SMD Top View Package LED SMP4-SRYB, RED/YELLOW/BLUE Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Yellow Blue Red Red, Yellow, Blue Blue Red, Yellow Red Yellow Blue Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision C 10/13 Page 3 of 5 PLCC4 SMD Top View Package LED SMP4-SRYB, RED/YELLOW/BLUE Recommended Soldering Conditions Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision C 10/13 Page 4 of 5 PLCC4 SMD Top View Package LED SMP4-SRYB, RED/YELLOW/BLUE 0.63 [16.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision C 10/13 Page 5 of 5
SMP4-SRYB 价格&库存
很抱歉,暂时无法提供与“SMP4-SRYB”相匹配的价格&库存,您可以联系我们找货
