PLCC2 SMD Top View Package LED
SMP2-SRC, SUPER RED
SMP2-SRC
Industry Standard PLCC2 Footprint
Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMP2 LED is offered in an industry standard PLCC2 package with high luminous intensity and wide
viewing angles. The miniature package is ideal for small scale applications such as illumination, general
indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The robust package is ideal for harsh working environments and can be used in
clusters for high luminous applications. Wide variety of color and intensity combinations are available to
meet any illumination needs. Bivar SMP2 LED is packaged in standard tape and reels for pick and place
assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
Lens Color
Viewing Angle
SMP2-SRC
AlGaInP
Super Red
180
Water Clear
120°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 02/15
Page 1 of 5
SMP2-SRC, SUPER RED
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
72 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-40 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Lead Soldering Temperature ( 1.6 mm from body ) 2
260°C
Electrostatic Discharge (HBM)
2000 V
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
Super
Red
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current (µA)
VR=5V
Dominant
Wavelength (nm)2
Luminous
Intensity (mcd)3
Viewing
Angle
2 Ө ½ (deg)
TYP
MAX
TYP
MAX
MIN
TYP
MAX
MIN
TYP
TYP
1.9
2.4
624
631
640
115
180
120
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision B 02/15
Page 2 of 5
SMP2-SRC, SUPER RED
Typical Electrical / Optical Characteristics Curves
Revision B 02/15
Page 3 of 5
SMP2-SRC, SUPER RED
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 2000 pcs/Reel
Revision B 02/15
Page 4 of 5
SMP2-SRC, SUPER RED
0.35 [9.0mm]
0.47 [12.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Vacuum and Heat Sealed
Clear AntiStatic Poly Bag
Internal Quality Control Label
X.XXX
Humidity Indicator
Card
X.XXX
Desiccant
Bivar Standard Packaging Label
Revision B 02/15
Page 5 of 5
很抱歉,暂时无法提供与“SMP2-SRC”相匹配的价格&库存,您可以联系我们找货
