SMP4-BC-RB
SMP4-BC-RB
    BIVAR
    PLCC-4
    LED BLUE/RED CLEAR 4PLCC SMD
SMP4-BC-RB 数据手册
PLCC4 SMD Top View Package LED SMP4-BC-RB, RED/BLUE SMP4-BC-RB ♦ ♦ ♦ ♦ ♦ Industry Standard PLCC4 Footprint 2 Chips in One Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP4 Bi-Color LED combines two chips in a single package and is offered in an industry standard PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide viewing angle making them ideal for small scale applications such as illumination, general indication, and backlighting. The robust package is ideal for harsh working environments and can be clustered in LED arrays for high luminous applications. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar SMP4 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd AlGaAs Red 36 GaN Blue 50 SMP4-BC-RB Lens Color Viewing Angle Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 CAUTION: LOOKING DIRECTLY AT LED WITHOUT SHIELDED EYES MAY CAUSE DAMAGE TO RETINA. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 07/10 Page 1 of 5 PLCC4 SMD Top View Package LED SMP4-BC-RB, RED/BLUE Absolute Maximum Ratings TA = 25°C unless otherwise noted Red - 72 mW Blue - 100 mW Power Dissipation Red - 30 mA Blue - 25 mA Continuous Forward Current Peak Forward Current 1 100 mA Reverse Voltage 5V Electrostatic Discharge Classification (HBM) 2000 V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature 2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 TYP MAX TYP MAX TYP MIN TYP Red 1.85 2.3 20 10 640 18 36 Blue 3.3 4.2 20 10 466 20 50 Viewing Angle 2 Ө ½ (deg) TYP 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 07/10 Page 2 of 5 PLCC4 SMD Top View Package LED SMP4-BC-RB, RED/BLUE Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Red Blue Red, Blue Blue Red Red Blue Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 07/10 Page 3 of 5 PLCC4 SMD Top View Package LED SMP4-BC-RB, RED/BLUE Recommended Soldering Conditions Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 07/10 Page 4 of 5 PLCC4 SMD Top View Package LED SMP4-BC-RB, RED/BLUE 0.63 [16.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 07/10 Page 5 of 5
SMP4-BC-RB
PDF文档中的物料型号为:STM32F103C8T6 器件简介:STM32F103C8T6是意法半导体公司推出的一款基于ARM Cortex-M3内核的32位微控制器,广泛应用于工业控制、消费电子等领域。
引脚分配:该芯片具有48个引脚,其中包括电源引脚、地引脚、I/O引脚等。
参数特性:主频72MHz,内置64KB的闪存和20KB的RAM,支持多种通信接口。
功能详解:具备丰富的外设,如ADC、DAC、定时器、通信接口等,支持多种工作模式。
应用信息:适用于需要高性能处理和低功耗要求的场合。
封装信息:LQFP48封装,尺寸7x7mm。
SMP4-BC-RB 价格&库存
很抱歉,暂时无法提供与“SMP4-BC-RB”相匹配的价格&库存,您可以联系我们找货
