PLCC4 SMD Top View Package LED
SMP4-SBC, RED/GREEN
SMP4-SBC
Industry Standard PLCC4 Footprint
2 Super Bright Chips in One Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMP4 Super Bright Bi-Color LED combines two chips in a single package and is offered in an industry
standard PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide
viewing angle making them ideal for outdoor illumination applications where higher ambient lighting conditions exist. The robust package is ideal for harsh working environments and can be clustered in LED arrays for maximum illumination. Low power consumption and excellent long life reliability are suitable for
battery powered equipment. Bivar SMP4 LED is packaged in standard tape and reels for pick and place
assemblies.
Part Number
SMP4-SBC
Material
Emitted Color
Lumen Typ. mcd
AlGaInP
Red
180
AlGaInP
Green
115
Lens Color
Viewing Angle
Water Clear
120°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
CAUTION: LOOKING DIRECTLY AT
LED WITHOUT SHIELDED EYES
MAY CAUSE DAMAGE TO RETINA.
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 07/10
Page 1 of 5
SMP4-SBC, RED/GREEN
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
72 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Electrostatic Discharge Classification (HBM)
2000 V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-40 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Soldering Temperature 2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current (µA)
VR=5V
Dominant
Wavelength (nm)2
Luminous
Intensity (mcd)3
TYP
MAX
TYP
MAX
TYP
MIN
TYP
Red
1.9
2.4
631
115
180
Green
1.9
2.4
574
57
115
Viewing
Angle
2 Ө ½ (deg)
TYP
120
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision B 07/10
Page 2 of 5
SMP4-SBC, RED/GREEN
Typical Electrical / Optical Characteristics Curves
Red
Green
Red
Green
Red, Green
Red, Green
Revision B 07/10
Page 3 of 5
SMP4-SBC, RED/GREEN
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 2000 pcs/Reel
Revision B 07/10
Page 4 of 5
SMP4-SBC, RED/GREEN
0.63 [16.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator
Card
X.XXX
Desiccant
Bivar Standard Packaging Label
Revision B 07/10
Page 5 of 5
很抱歉,暂时无法提供与“SMP4-SBC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.87000
- 200+1.14524
- 500+1.10690
- 1000+1.08800
