PLCC6 SMD Top View Package LED
SMP6-UWDW, WARM WHITE
SMP6-UWDW
Industry Standard PLCC6 Footprint
Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Equipped with Protective Zener Diode
Bivar SMP6 LED is offered in an industry standard PLCC6 package with high luminous intensity and wide
viewing angles. The miniature package is ideal for small scale applications such as illumination, general
indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The flexible three chip design allows for a wide variety of lighting options where
the chips can be individually driven or in combinations. Bivar SMP6 LED is packaged in standard tape
and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
Lens Color
Viewing Angle
SMP6-UWDW
InGaN
Warm White
4000
Diffused
140°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision C 02/15
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
100 mW
Continuous Forward Current
30 mA
Peak Forward Current 1
75 mA
Electrostatic Discharge Classification (HBM)
2000 V
Reverse Voltage
5V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-30 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Soldering Temperature
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 60 mA unless otherwise noted
Emitting
Color
Warm
White
Recommend
Forward
Current (mA)
Forward
Voltage (V)1
MIN
TYP MAX
3.0
3.3
3.6
Reverse
Viewing
Chromaticity
Luminous
Current (µA) Coordinates (XY)2 /
Angle
Intensity (mcd)3
VR=5V
2 Ө ½ (deg)
CCT (Kelvin)
TYP
MAX
TYP
MIN
MAX
TYP
60
10
X=0.34 , Y=0.34
4500K
3000
5000
140
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Chromaticity Coordinates : ±0.02.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision C 02/15
Page 2 of 5
Typical Electrical / Optical Characteristics Curves
Revision C 02/15
Page 3 of 5
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 1000 pcs/Reel
Revision C 02/15
Page 4 of 5
Packaging and Labeling Plan
Note: 1 Reel / Bag
Vacuum and Heat Sealed
Clear AntiStatic Poly Bag
Internal Quality Control Label
X.XXX
Humidity Indicator
Card
Desiccant
X.XXX
Bivar Standard Packaging Label
Revision C 02/15
Page 5 of 5
很抱歉,暂时无法提供与“SMP6-UWDW”相匹配的价格&库存,您可以联系我们找货
