3AD5V
3AD5V
    BIVAR
    T-1
    发光二极管/LED 径向
3AD5V 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN, TURQUOISE, BLUE, YELLOW, AMBER, Low Ultra 5V Ultra Super Low Current Bright Ultra Bright Current Bright Bright AMBER, 5V B 3AD5V-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Diffused Lens Available in Flange (F), Standard (Blank), and Shouldered (S) Lead Frame styles 5V Operating Voltage Ideal for Status Indication and Display Bivar 3mm T1 Package 5V LED is ideal for those applications equipped with regular 5V power supplies such as servers and computer peripherals. Bivar offers diffused LED lens for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies, the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends, and the Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. 3AD5V-F 3AD5V GaAsP/Gap AMBER 605nm 3AD5V-S Lens Appearance Viewing Angle Amber Diffused 35° Amber Diffused 40° Amber Diffused 40° Part Number Designation 3 X X 5V - X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, -S, Blank for Standard 5V Operating Voltage ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright AMBER, 5V Outline Dimensions Flanged “3XX5V-F” LED Standard “3XX5V” LED Shouldered Lead “3XX5V-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright AMBER, 5V Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation / mW Forward Current ( DC ) Peak Forward Current 8 mA 1 12 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & Vf = 5V unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX 3AD5V-F 3AD5V / / 5.0 / / 3AD5V-S Notes: 1. Tolerance of forward voltage : ±0.05V. / 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 25 / 35 / / / / 25 / 40 / / / / 25 / 40 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright AMBER, 5V Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 50° 35° 40° 0.5 60° 70° 80° 0.0 550 λ(nm) 600 650 700 90° 0.5 750 Fig. 1 Relative Luminous Intensity vs. Wavelength 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv 3.0 2.0 1.0 0.0 T (°C) -40 0 40 80 Fig. 3 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, TURQUOISE, BLUE, GREEN, YELLOW, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright AMBER, 5V Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 5 of of 4 5
3AD5V 价格&库存
很抱歉,暂时无法提供与“3AD5V”相匹配的价格&库存,您可以联系我们找货
