3ADL-201
3ADL-201
    BIVAR
    T-1
    发光二极管/LED 径向
3ADL-201 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, YELLOW, GREEN, AMBER, Low Ultra Low 5V 12V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright Extended AMBER, Low Current Extended Profile Profile B 3ADL-201-X ♦ ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Diffused Lens Extended Body Profile Available in a Shouldered (S) Lead Frame Style 2 mA Low Operating Current Ideal for Status Indication and Display Bivar 3mm T1 Package Low Current Extended Profile LED is special binned at 2 mA and is ideal for those applications where lower power budget is required such as solar panel or battery-powered portable devices and provides additional protrusion for thicker faceplates. Bivar offers diffused LED lens for uniform light output. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance Viewing Angle 3ADL-201-S GaAsP/GaP AMBER 605nm Amber Diffused 35° Part Number Designation 3 X X L -2 0 1-X LED Body, mm Emitted Color Lead Frame & Body Style i.e. -S, Shouldered Extended Profile Lens Appearance Low Current ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, AMBER, BLUE, GREEN, YELLOW, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright Extended ExtendedProfile Profile AMBER, Low Current Extended Profile Outline Dimensions Shouldered Lead “3XXL-201-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, AMBER, BLUE, GREEN, YELLOW, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright Extended ExtendedProfile Profile AMBER, Low Current Extended Profile Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 10 mW Forward Current ( DC ) 7 mA Peak Forward Current 1 / mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 2 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 3ADL-201-S / 2.0 2.8 / 2 Notes: 1. Tolerance of forward voltage : ±0.05V. Reverse Dominant Current Wavelength (nm)2 (μA) Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 100 / / / / 2 / 35 / 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, AMBER, BLUE, GREEN, YELLOW, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright Extended ExtendedProfile Profile AMBER, Low Current Extended Profile Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 20° 10° 30° 1.0 40° 35° 50° 0.5 60° 70° 80° 0.0 550 λ(nm) 600 650 700 90° 750 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 3 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 4 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, AMBER, BLUE, GREEN, YELLOW, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright Extended ExtendedProfile Profile AMBER, Low Current Extended Profile Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A C 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
3ADL-201 价格&库存
很抱歉,暂时无法提供与“3ADL-201”相匹配的价格&库存,您可以联系我们找货
