engineered to light up your design
www.vcclite.com
1.800.522.5546
CMDA2 Series HIGH BRIGHTNESS 1206 Package Size Surface Mount LED
Description and Features
Features
• High brightness
• Small size
• Industry standard 1206
Footprint
• Diffused optics
• Top emitting
• Compatible with IR
solder profiles
• Ideal for use with Light
Pipes
• Available in 8 mm tape
on 7" diameter reel
• Packaged 3,000 pieces
per reel
• RoHS Compliant
NOTES:
1. All dimensions are in millimeters (in).
2. 1 micro second @ 10% duty cycle
Applications
• LCD backlighting
• Push button
backlighting
• Front panel indicator
• Symbol indicator
• Microdisplays
• Small message panel
signage
Electro-Optical Characteristics and Ratings
Part
Number
Output
Color
Diffusion
Package
Color
Test
Current
(mA)
Forward
Voltage
Typ. (V)
CMDA2DY7D1S
Amber
Diffused
White
2.4
CMDA2AR7D1S
Red
Diffused
White
2.4
CMDA2BA7D1S
Orange
Diffused
White
2.4
Forward
Luminous
Voltage
Intensity
Max. Typ. (V) Min. (mcd)
Luminous
Intensity
Typ. (mcd)
Peak
Wavelength
(nm)
Viewing
Angle
(Degrees)
25
90
595
170
25
90
637
170
25
90
609
170
Absolute Maximum Ratings to = 25°C
Part
Number
Power
Dissipation
(mW)
Operating
Temperature
(°C)
Storage
Temperature
(°C)
Peak Forward
Current Max.
(See note 2) (mA)
Reverse Voltage
(IR = 100 mA)
(V)
Lead Solder Time
at 230°C
(Seconds)
DY
75
-30 to +85
-40 to +85
100
5
10
AR
75
-30 to +85
-40 to +85
100
5
10
BA
75
-30 to +85
-40 to +85
100
5
10
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“CMDA2AA7D1S”相匹配的价格&库存,您可以联系我们找货
