ZSM-S3806-W
ZSM-S3806-W
    JKLCOMPONENTS
    侧发光LED
    ZSM-S3806-W
ZSM-S3806-W 数据手册
SURFACE MOUNT WHITE LED SIDE VIEW 3.8 X 1.0 X 0.6mm FEATURES SIDE VIEW WHITE LED (3.8 x 1.0 x 0.6mm) WHITE SMT PACKAGE LEAD FRAME PACKAGE WITH INDIVIDUAL 2-PINS GaN WITH YELLOW PHOSPHOR WIDE VIEW ANGLE (X: 120°/Y: 120°) IR REFLOW SOLDERING Pb FREE 1.0 0.7 3.5 CATHODE MARK 3.8 2.1 0.6 0.47 1.3 1.3 2.1 1.1 RECOMMENDED SOLDERING PAD LAYOUT JKL PART NO.: ZSM-S3806-W Pb Pb-free DRAWN BY COMPONENTS CORPORATION L. WENGSTROM APPV'D BY L.R. DATE 12/22/14 DRAWING NO. ZSM-S3806-W RELEASED DATE REVISION DATE 6/14/07 12/22/14 REV. NO. E SHEET 1 OF 5 SURFACE MOUNT WHITE LED SIDE VIEW 3.8 X 1.0 X 0.6mm SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS (TA = 25°C) (LED die) ITEM Forward Current Pulse Forward Current* Reverse Voltage Power Dissipation Operating Temperature Storage Temperature Soldering Temperature SYMBOL IF I FP VR PD T opr T stg T sld ABSOLUTE MAXIMUM RATING UNIT mA 30 mA 100 V 5 mW 105 °C -30 +85 °C -40 +100 Reflow Soldering: 260° C for 10 secs Hand Soldering: 350° C for 3 secs ELECTRICAL & OPTICAL OPERATING CHARACTERISTICS (TA = 25°C) ITEM Forward Voltage Luminous Intensity Color Coordinates Viewing Angle SYMBOL CONDITION VF I F = 20mA LV I F = 20mA I F = 20mA x, y --- I F = 20mA MIN 2.8 6.5 .275 .235 120° x DRAWN BY COMPONENTS CORPORATION L. WENGSTROM APPV'D BY L.R. DATE 12/22/14 UNIT Volt lm x y Degrees MAX 3.4 9.75 .305 .295 120° y DRAWING NO. ZSM-S3806-W RELEASED DATE REVISION DATE 6/14/07 12/22/14 REV. NO. E SHEET 2 OF 5 SURFACE MOUNT WHITE LED SIDE VIEW 3.8 X 1.0 X 0.6mm BIN RANGE OF CHROMATICITY COORDINATES CHROMATICITY DIAGRAM BIN CODE DEFINITION DRAWN BY COMPONENTS CORPORATION L. WENGSTROM APPV'D BY L.R. DATE 12/22/14 DRAWING NO. ZSM-S3806-W RELEASED DATE REVISION DATE 6/14/07 12/22/14 REV. NO. E SHEET 3 OF 5 SURFACE MOUNT WHITE LED SIDE VIEW 3.8 X 1.0 X 0.6mm TYPICAL ELECTRO-OPTICAL CHARACTERISTICS CURVES Forward Voltage vs. Forward Current Forward Current vs. Chromaticity Diagram Forward Current vs. Relative Luminosity Ambient Temperature vs. Relative Luminous Ambient Temperature vs. Allowable Forward Current DRAWN BY COMPONENTS CORPORATION L. WENGSTROM APPV'D BY L.R. DATE 12/22/14 DRAWING NO. ZSM-S3806-W RELEASED DATE REVISION DATE 6/14/07 12/22/14 REV. NO. E SHEET 4 OF 5 SURFACE MOUNT WHITE LED SIDE VIEW 3.8 X 1.0 X 0.6mm TYPICAL ELECTRO-OPTICAL CHARACTERISTICS CURVES (Continued) Spectrum Radiation Pattern PACKAGING: 5000 pcs/REEL NOTES: 1. 2. 3. 4. 5. 6. STORE IN ORIGINAL MOISTURE PROOF PACKAGING. PACKAGING SHOULD BE STORED AT 30°C OR LESS AND AT 60% RH OR LESS. LED SHOULD BE SOLDERED WITHIN 168 HOURS AFTER OPENING. LED'S ARE STATIC SENSITIVE DEVICES. DO NOT HANDLEWITHOUT APPROPRIATE STATIC PROTECTION. CLEAN ONLY WITH ISOPROPYL ALCOHOL. DO NOT USE ULTRASONIC CLEANING. CAUTION: DO NOT LOOK DIRECTLY INTO LIT LED. INJURY TO EYES CAN OCCUR. DRAWN BY COMPONENTS CORPORATION L. WENGSTROM APPV'D BY L.R. DATE 12/22/14 DRAWING NO. ZSM-S3806-W RELEASED DATE REVISION DATE 6/14/07 12/22/14 REV. NO. E SHEET 5 OF 5
ZSM-S3806-W 价格&库存
很抱歉,暂时无法提供与“ZSM-S3806-W”相匹配的价格&库存,您可以联系我们找货
