CMDA6BR7D1S
CMDA6BR7D1S
    VCC
    发光二极管/LED 0603
CMDA6BR7D1S 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMDA6 Series 0603 Package Size Surface Mount LED Description and Features Features • Small size • Industry standard 0603 Footprint • Compatible with IR solder profiles • Ideal for use with Light Pipes • Diffused optics • Top emitting • Available in 8 mm • Tape on 7" diameter reels • Packaged 4,000 pieces per reel •RoHS Compliant NOTES: 1. All dimensions are in millimeters (in). 2. 1 micro second @ 10% duty cycle Applications • Keypad backlighting • Push-button backlighting • LCD backlighting • Symbol backlighting • Front panel indicator Electro-Optical Characteristics and Ratings Part Number Output Color Diffusion CMDA6AY7D1S Green Diffused CMDA6DR7D1S Red Diffused Package Color Test Current (mA) Forward Voltage Typ. (V) Forward Luminous Voltage Intensity Max. Typ. (V) Min. (mcd) Clear 20 2.2 2.6 Clear 20 1.8 2.6 Luminous Intensity Typ. (mcd) Peak Wavelength (nm) Viewing Angle 28 1/2 (°) 4.0 15 570 170 6.3 17 660 170 Absolute Maximum Ratings to = 25°C Part Number Power Dissipation (mW) Operating Temperature (°C) Storage Temperature (°C) Peak Forward Current Max. (See note 2) (mA) Reverse Voltage (IR = 100 mA) (V) Lead Solder Time at 230°C (Seconds) AY 52 -30 to +85 -40 to +85 100 5 10 DR 65 -30 to +85 -40 to +85 100 5 10 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
CMDA6BR7D1S 价格&库存
很抱歉,暂时无法提供与“CMDA6BR7D1S”相匹配的价格&库存,您可以联系我们找货
