3YD5V
3YD5V
    BIVAR
    T-1
    发光二极管/LED 径向
3YD5V 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER AMBER, GREEN, TURQUOISE, BLUE, YELLOW, Low Ultra Ultra Super 5V Low Current Bright Ultra Bright Current Bright Bright YELLOW, 5V B 3YX5V-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Shouldered (S) Lead Frame styles 5V Operating Voltage Ideal for Status Indication and Display Bivar 3mm T1 Package 5V LED is ideal for those applications equipped with regular 5V power supplies such as servers and computer peripherals. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Viewing Angle 3YC5V-F Water Clear 20° 3YD5V-F Yellow Diffused 35° Yellow Tinted 20° Water Clear 30° 3YD5V-S Yellow Diffused 40° 3YT5V-S Yellow Tinted 30° 3YC5V-S GaAsP/Gap Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 3YT5V-F Material YELLOW 590nm Part Number Designation 3 X X 5V - X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, -S 5V Operating Voltage ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, GREEN, YELLOW, AMBER, Low Ultra Low 5V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright YELLOW, 5V Outline Dimensions Flanged “3XX5V-F” LED Shouldered Lead “3XX5V-S” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, GREEN, YELLOW, AMBER, Low Ultra Low 5V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright YELLOW, 5V Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation / mW Forward Current ( DC ) 8 mA Peak Forward Current 1 12 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & Vf = 5V unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 20 / / / / 20 / 35 3YT5V-F / / / / 40 / 20 3YC5V-S / / / / 40 / 30 / / / / 20 / 40 / / / / 40 / 30 3YC5V-F 3YD5V-F 3YD5V-S / / / / 5.0 5.0 / / / / / 100 / 100 3YT5V-S Notes: 1. Tolerance of forward voltage : ±0.05V. 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, GREEN, YELLOW, AMBER, Low Ultra Low 5V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright YELLOW, 5V Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 20° 30° 35° 50° 40° 0.5 60° 70° 80° 0.0 500 λ(nm) 550 600 650 90° 700 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv 3.0 2.0 1.0 0.0 T (°C) -40 0 40 80 Fig. 3 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, GREEN, YELLOW, AMBER, Low Ultra Low 5V Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright YELLOW, 5V Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A 01/16/08 Revision B 06/15 Page Page 4 5 of of 4 5
3YD5V 价格&库存
很抱歉,暂时无法提供与“3YD5V”相匹配的价格&库存,您可以联系我们找货
