5mm
3mm
(T1
Package
Package
Discrete
Discrete
LED
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER/GREEN,
YELLOW/GREEN,
Tri-Color
YELLOW/GREEN,Tri-Color
Bi-Color
5BC-3-Y/G-CA-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
White Diffused Lens
Available in Flange (F) Lead Frame styles
3-Lead Bi-Color LED
Ideal for Status Indication and Display
Bivar 5mm T1 ¾ Package Tri-Color LED is ideal for those applications where multiple signals need to
be displayed at the same location such as standby-on indication for server or computer peripherals.
When needed, the 3rd color signal could be created by powering up both chips together for on-offstandy applications that require three distinct signals. Bivar offers white diffused LED lens for uniform
light output. The Flange LED is ideal for Panel Mount Clip & Ring assemblies. This 3-Lead Bi-Color
LED package comes in a common anode Lead Frame configuration.
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaAsP/GaP
YELLOW
590nm
GaP/GaP
GREEN
568nm
Part Number
5BC-3-Y/G-CA-F
Lens Appearance
Viewing Angle
White Diffused
40°
Part Number Designation
5 B C - 3 -X X - X X - X
Lead Frame & Body Style
i.e. –F for Flanged
LED Body, mm
Bi-Color
• Common Anode, CA
• Common Cathode, “ ”
Tri-Lead
Emitted Colors, i.e. Y/G, “ ” for R/G
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision B 08/15
Page 1 of 5
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
YELLOW/GREEN, Bi-Color
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 08/15
Page 2 of 5
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part
Number
Emitted
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
5BC-3Y/G-CA-F
Yellow
2.0
2.8
Green
2.1
2.8
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
100
MIN
Viewing
Angle
2Ө½
(deg)
Luminous
Intensity Iv
(mcd)
TYP MAX MIN TYP MAX
4
6
TYP
40
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 08/15
Page 3 of 5
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.
40°
40°
50°
0.5
60°
70°
80°
0.0
500
550
λ(nm)
600
650
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
2.0
3.0
4.0
5.0
Vf (V)
Fig. 3 Forward Current vs. Forward Voltage
0.0
1
10
100
1000
If (mA)
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
1.2
3.0
1.1
2.0
1.0
1.0
0.9
0.8
-40
T (°C)
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 08/15
Page 4 of 5
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A B
01/16/08
Revision
08/15
Page
Page 4
5 of
of 4
5
很抱歉,暂时无法提供与“5BC-3-Y/G-CA”相匹配的价格&库存,您可以联系我们找货
