PLTR5-250-PR2
PLTR5-250-PR2
    BIVAR
    RIGIDLIGHTPIPES
PLTR5-250-PR2 数据手册
REV. B NOTES: 1. ALL ITEMS SHIPPED NON-ASSEMBLED. 2. SEALED TO IP67 RATING. DESCRIPTION DATE 4/4/17 Engineering Release APPROVED J.C. SEAL POLYURETHANE, 94V-0 WASHER, WHITE NYLON, 94V-0 LIGHT PIPE CLEAR PC, 94V-0 NUT, M4 X 0.50, WHITE NYLON, 94V-0 TORQUE: 10-11 in-oz 0.315in 8.0mm REF 0.050in 1.3mm 0.197in 5.0mm 0.25in 6.4mm TABLE A L HOLD HEAD WHILE TORQUING NUT +0.003 +0.08 0.177in - 0.001 4.50mm - 0.03 RECOMMENDED MOUNTING HOLE PANEL THICKNESS: 0.047" - 0.093" PART NUMBER CONFIGURATION PANEL, REF PART No. PLTR5-250-PRX PLTR5-500-PRX PLTR5-1000-PRX PLTR5-1500-PRX PLTR5-2000-PRX PLTR5-2500-PRX PLTR5-3000-PRX PLTR5-8MM-PRX PLTR5-16MM-PRX PLTR5-24MM-PRX PLTR5-32MM-PRX PLTR5-40MM-PRX PLTR5-48MM-PRX PLTR5-56MM-PRX PLTR5-64MM-PRX PLTR5-72MM-PRX TABLE B (SEAL) L = BODY LENGTH 0.250 (6.4mm) 0.500 (12.7mm) 1.000 (25.4mm) 1.500 (38.1mm) 2.000 (50.8mm) 2.500 (63.5mm) 3.000 (76.2mm) 8mm (0.315") 16mm (0.630") 24mm (0.945") 32mm (1.260") 40mm (1.575") 48mm (1.890") 56mm (2.205") 64mm (2.520") 72mm (2.835") COLOR BLACK WHITE CODE 1 2 TABLE C (DYE) COLOR BLUE BLACK GREEN GRAY RED YELLOW NONE CODE BE BK GN GY RD YW BLANK  STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) PLTR5-XXX-PRX XX LIGHT PIPE DYED COLOR, TABLE C SEAL COLOR, TABLE B L = BODY LENGTH, TABLE A DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: TD. NGUYEN CHECKED: J. CHIANG ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: LIGHT PIPE, 5mm, IP67 DATE: 4/4/17 DATE: 4/4/17 PART NO: PLTR5-XXX-PRX REVISION: B CAGE CODE : 32559 SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
PLTR5-250-PR2
1. 物料型号:文档列出了多种型号,例如PLTR5-250-PRX、PLTR5-500-PRX等,这些型号以PLTR5开头,后跟数字表示长度,以PRX结尾。
2. 器件简介:文档提到了LIGHT PIPE CLEAR PC,这是一种密封到IP67等级的透明聚碳酸酯材料制成的光导管。
3. 引脚分配:文档中没有明确提到引脚分配,但提到了M4 X 0.50的螺母和相应的扭矩规格。
4. 参数特性:文档提供了一些尺寸参数,例如光导管的直径为5.0mm,推荐安装孔的面板厚度为0.047" - 0.093"。
5. 功能详解:文档中没有详细描述功能,但提到了光导管的密封等级为IP67。
6. 应用信息:文档没有提供具体的应用信息,但可以推断这些光导管可能用于需要密封和光线传输的场合。
7. 封装信息:文档提供了不同长度的光导管型号,从PLTR5-250-PRX(0.250英寸)到PLTR5-72MM-PRX(72mm),以及颜色代码表,包括黑色、白色、蓝色等。
PLTR5-250-PR2 价格&库存
很抱歉,暂时无法提供与“PLTR5-250-PR2”相匹配的价格&库存,您可以联系我们找货
PLTR5-250-PR2
  • 1+27.27258
  • 5+24.31531
  • 7+18.64722
  • 17+17.66146
库存:4
