REV.
B
NOTES:
1. ALL ITEMS SHIPPED NON-ASSEMBLED.
2. SEALED TO IP67 RATING.
SEAL
POLYURETHANE, 94V-0
LIGHT PIPE
CLEAR PC, 94V-0
DESCRIPTION
DATE
4/4/17
Engineering Release
APPROVED
J.C.
WASHER, WHITE NYLON, 94V-0
NUT, M3 X 0.50, WHITE NYLON, 94V-0
TORQUE: 6-7 in-oz
0.276in 7.0mm
REF
0.030in 0.8mm
0.138in 3.5mm
TABLE A
0.25in 6.4mm
L
PANEL, REF
HOLD HEAD
WHILE TORQUING NUT
+0.002
+0.05
0.130in - 0.001 3.30mm - 0.03
RECOMMENDED MOUNTING HOLE
PANEL THICKNESS: 0.047" - 0.093"
PART No.
PLTR2-250-PRX
PLTR2-500-PRX
PLTR2-1000-PRX
PLTR2-1500-PRX
PLTR2-2000-PRX
PLTR2-2500-PRX
PLTR2-3000-PRX
PLTR2-8MM-PRX
PLTR2-16MM-PRX
PLTR2-24MM-PRX
PLTR2-32MM-PRX
PLTR2-40MM-PRX
PLTR2-48MM-PRX
PLTR2-56MM-PRX
PLTR2-64MM-PRX
PLTR2-72MM-PRX
TABLE B (SEAL)
L = BODY LENGTH
0.250 (6.4mm)
0.500 (12.7mm)
1.000 (25.4mm)
1.500 (38.1mm)
2.000 (50.8mm)
2.500 (63.5mm)
3.000 (76.2mm)
8mm (0.315")
16mm (0.630")
24mm (0.945")
32mm (1.260")
40mm (1.575")
48mm (1.890")
56mm (2.205")
64mm (2.520")
72mm (2.835")
COLOR
BLACK
WHITE
CODE
1
2
TABLE C (DYE)
COLOR
BLUE
BLACK
GREEN
GRAY
RED
YELLOW
NONE
CODE
BE
BK
GN
GY
RD
YW
BLANK
PART NUMBER CONFIGURATION
STANDARD TOLERANCE
PLTR2-XXX-PRX XX
(UNLESS OTHERWISE SPECIFIED)
DECIMALS
LIGHT PIPE DYED COLOR, TABLE C
SEAL COLOR, TABLE B
L = BODY LENGTH, TABLE A
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
TD. NGUYEN
CHECKED:
J. CHIANG
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: LIGHT PIPE, 3.5mm, IP67
DATE:
4/4/17
DATE:
4/4/17
PART NO:
PLTR2-XXX-PRX
REVISION:
B
CAGE CODE : 32559 SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
很抱歉,暂时无法提供与“PLTR2-56MM-PR1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+36.356331+4.70581
- 10+26.7143210+3.45779
- 100+21.00950100+2.71938
- 500+18.50636500+2.39539
- 1000+17.691921000+2.28997
- 2000+17.002832000+2.20078
- 5000+16.252175000+2.10362
- 国内价格
- 100+27.71709
- 500+25.04600
- 1000+22.12337
- 10000+19.45227
- 国内价格 香港价格
- 100+29.85729100+3.86460
- 500+26.97632500+3.49170
- 1000+23.833451000+3.08490
- 10000+20.9524810000+2.71200
