PLTR2-56MM-PR2
PLTR2-56MM-PR2
    BIVAR
    RIGIDLIGHTPIPES
PLTR2-56MM-PR2 数据手册
REV. B NOTES: 1. ALL ITEMS SHIPPED NON-ASSEMBLED. 2. SEALED TO IP67 RATING. SEAL POLYURETHANE, 94V-0 LIGHT PIPE CLEAR PC, 94V-0 DESCRIPTION DATE 4/4/17 Engineering Release APPROVED J.C. WASHER, WHITE NYLON, 94V-0 NUT, M3 X 0.50, WHITE NYLON, 94V-0 TORQUE: 6-7 in-oz 0.276in 7.0mm REF 0.030in 0.8mm 0.138in 3.5mm TABLE A 0.25in 6.4mm L PANEL, REF HOLD HEAD WHILE TORQUING NUT +0.002 +0.05 0.130in - 0.001 3.30mm - 0.03 RECOMMENDED MOUNTING HOLE PANEL THICKNESS: 0.047" - 0.093" PART No. PLTR2-250-PRX PLTR2-500-PRX PLTR2-1000-PRX PLTR2-1500-PRX PLTR2-2000-PRX PLTR2-2500-PRX PLTR2-3000-PRX PLTR2-8MM-PRX PLTR2-16MM-PRX PLTR2-24MM-PRX PLTR2-32MM-PRX PLTR2-40MM-PRX PLTR2-48MM-PRX PLTR2-56MM-PRX PLTR2-64MM-PRX PLTR2-72MM-PRX TABLE B (SEAL) L = BODY LENGTH 0.250 (6.4mm) 0.500 (12.7mm) 1.000 (25.4mm) 1.500 (38.1mm) 2.000 (50.8mm) 2.500 (63.5mm) 3.000 (76.2mm) 8mm (0.315") 16mm (0.630") 24mm (0.945") 32mm (1.260") 40mm (1.575") 48mm (1.890") 56mm (2.205") 64mm (2.520") 72mm (2.835") COLOR BLACK WHITE CODE 1 2 TABLE C (DYE) COLOR BLUE BLACK GREEN GRAY RED YELLOW NONE CODE BE BK GN GY RD YW BLANK PART NUMBER CONFIGURATION  STANDARD TOLERANCE PLTR2-XXX-PRX XX (UNLESS OTHERWISE SPECIFIED) DECIMALS LIGHT PIPE DYED COLOR, TABLE C SEAL COLOR, TABLE B L = BODY LENGTH, TABLE A .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: TD. NGUYEN CHECKED: J. CHIANG ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: LIGHT PIPE, 3.5mm, IP67 DATE: 4/4/17 DATE: 4/4/17 PART NO: PLTR2-XXX-PRX REVISION: B CAGE CODE : 32559 SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
PLTR2-56MM-PR2 价格&库存
很抱歉,暂时无法提供与“PLTR2-56MM-PR2”相匹配的价格&库存,您可以联系我们找货
PLTR2-56MM-PR2
  • 1+24.270111+3.04622
  • 10+17.5596410+2.20397
  • 100+13.57425100+1.70375
  • 500+11.81960500+1.48352
  • 1000+11.247691000+1.41173
  • 2000+10.763442000+1.35095
  • 5000+10.235755000+1.28472
库存:211
PLTR2-56MM-PR2
  • 100+18.80431
